Your most effective FE inspired modification - Fuelly Forums
Old 08-27-2007, 04:00 PM   #1
Besides driving habit changes, what do you feel was the most effective modification you've made to your vehicle, in terms of FE gains?
phantomcow2 is offline   Reply With Quote
Old 08-27-2007, 04:15 PM   #2
skewbe's Avatar
converting to a stick shift and installing a kill switch and a scangauge.
Standard Disclaimer
Old 08-27-2007, 04:59 PM   #3
psyshack's Avatar
Raised tire pressure
09 HCHII, w/Navi
07 Mazda3 S Touring, 5MT
Mild Hypermiler or Mad Man?
Old 08-27-2007, 05:18 PM   #4
MetroMPG's Avatar
Improvement in FE @ approx 55 mph:
Old 08-27-2007, 05:43 PM   #5
Installing a Tripminder computer.
Instant FE gauge for all EEC-IV Fords!
Old 08-27-2007, 06:16 PM   #6
Ebh
For the year, it's the extreme temp mods that help.
First and foremost: The Engine Block Heater...
When it's 10.0F, the engine is warm, and closed loop is not far away. Couple that with a grille block, and IATs/coolant temps are nominal. FE improvement follows.
Second, constant feedback -- the ScanGauge in particular. A simple feedback mod keeps the driver informed on how to be most efficient.
To keep a "Top 3" perspective: tire choice and high tire pressures help. LRR's with high pressures reduce friction -> increase FE.
RH77
Old 08-27-2007, 06:23 PM   #7
the thing that gave me biggst FE improvements was blocking off my egr valve on my truck and on my car im not too sure, too many factors. but tire pressure did help( i dont know what its supposed to be cuz the tire psi sticker is too faded to read. but thier at 33psi right now on new M+S tires
Old 08-27-2007, 07:11 PM   #8
I havent done much yet but Id say weight removal, upped tire pressure, aero, in that order
Old 08-27-2007, 07:31 PM   #9
kickflipjr's Avatar
Tire pressure is the most bang for you buck. $0 = a few mpg (if your tires are a bit low).
Not using AC.
I would say aero mods if you drive mostly in the +60mph range.
2008 EPA adjusted:
Old 08-27-2007, 10:50 PM   #10
I saw a drastic improvement with upping the psi in my tires. Followed up by removing weight.
Toyman321 is offline   Reply With Quote
google+ integration? xchrislee Fuelly Web Support and Community News 3 07-15-2011 01:55 AM
GasSavers.org Stickers Matt Timion Fuelly Web Support and Community News 7 10-12-2006 03:48 PM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 03:31 PM
Where to get parts? What parts do we need? Matt Timion Electric and Solar powered 11 09-19-2005 08:37 PM
