460 flex fuel - Fuelly Forums
Old 07-22-2013, 03:26 PM   #1
460 flex fuel
has anyone had experience cracking hydrocarbons?
i built a geet, but the 460 had no power
ive seen it is completely possible to crack hydrocarbons into simpler hydrocarbons, and use heat to take junk oil and make a "flammable smoke" that will power a spark engine. the patent list is 500 long
my idea is to use a heat exchanger to heat the oil to coolant temp, then spray through a nozzle into a tube that is as hot as the exhaust, cracking oils into lighter fractions, then putting that oil smoke under the carb. (hopefully running on the syngas alone with decent power)
i have most of the stuff to do this, but havent yet and im wondering if anyone has tried this.
i want a waste oil powered 460, but oils dont like to burn in an engine, without plasma spark, im also considering adding a plasma spark system to clean the plugs on start up and shut down when running waste oils, but running it constantly seems to wear out the plugs
i know about woodgas but dont have the room for a woodgas system
any suggestions welcome
smokin89 is offline   Reply With Quote
Old 07-23-2013, 06:46 AM   #2
Any oxygen present at all where the oil hits the hot oil will just lead to it burning there and making a mess. Wood gas is essentially just hydro cracking of the cellulose, and to do it with oil will take a similar set up.
Old 07-23-2013, 09:53 AM   #3
yes reduced or absolute minimal oxygen at the cracking zone is a must, i look forward to buying a carb spacer and trying several of these exhaust heat exchangers with veggie oil (since most of our wmo is synthetic) i know that if woodgas is powerful enough for towing, syngas from oil can get my truck to 60 mph, i do have a manual transmission, so it needs to be able to rev, another thought is having the carb as the fresh air control, and just having the fuel pump on when 3/4 throttle or above. like i said its not a daily driver so i look forward to experimenting.
Fantasy.....With Twins! shatto General Discussion (Off-Topic) 3 09-20-2009 05:56 PM
Honda Unveils Insight Concept in L.A. rgathright Automotive News, Articles and Products 2 11-26-2008 01:10 PM
savefuel.ca rangerbentman General Fuel Topics 4 03-08-2008 10:24 PM
Using a thread to brainstorm: Drive on Washington ketel0ne General Fuel Topics 12 09-30-2007 11:54 PM
Amazed by the SGII GeekGuyAndy General Discussion (Off-Topic) 7 08-18-2007 11:25 PM
