Acetone - Fuelly Forums
Old 11-08-2006, 01:28 PM   #1
GasSavers_lane's Avatar
Acetone
ive been using acetone for months with great results mpg went from a norm of 26-28 up to 30-36 mpg it definately works and makes my car start faster and run smoother.
does any one else have any expirience with using acetone???? i would like to know.
1-3 oz per 10 gallons gassoline
1-2 oz per 10 gallons diesel (bio or petroleum)
GasSavers_lane is offline   Reply With Quote
Old 11-08-2006, 01:43 PM   #2
Search the forums, there are several threads on it. I saw no effect.
What car do you have?
Old 11-08-2006, 08:39 PM   #3
i drive a 92 geo storm, maybe the gas your using contains ethanol? because using ethanol blend gas will neutralize the increased efficiency .
Old 11-08-2006, 08:46 PM   #4
The gasoline I used at the time did not.
You should be aware that I do not believe in acetone. The science isn't there, and neither is the empirical evidence, as far as I'm concerned.
Old 11-08-2006, 09:16 PM   #5
tomauto's Avatar
Send a message via AIM to tomauto Send a message via MSN to tomauto Send a message via Yahoo to tomauto
I wish it were just that easy...IF it was, than it would be in the gas already...
This same subject is what brought me here...but alas, it cannot ever be better than driving techniques.
Current Stable
tomauto is offline   Reply With Quote
Old 11-08-2006, 09:21 PM   #6
kickflipjr's Avatar
What do you think about it cleaning the injectors? I think that may be one advantage to acetone. If the car has clogged injectors puting some acetone in every few tanks MAY help.
I saw no real results when I used it. I have seen no results in anything except for driving style and conditions (of couse I don't have a sangauge so I can't test enything...)
2008 EPA adjusted:
Old 11-08-2006, 10:18 PM   #7
Thats my theory too.
This would explain why some get benifits and some do not.
I have posted about this before.
Down side is that acetone will eat injector O rings and rubber hoses (if fitted)
Old 11-09-2006, 07:10 AM   #8
zpiloto's Avatar
I think it helps a tiny bit but my theory is that when people start to use acetone they are trying to get better gas mileage thus change driving habits. I've have not seen any data from anyone with instantaneous FE feed back that has shown a gain or show data proving a gain.
Old 11-09-2006, 07:53 AM   #9
I've been using Acetone and other "additives" for 2 years now and it works great on both my vehicles. 97 Ford F150 (average 2 mpg increase) and 92 Saturn (average 5 mpg increase). My last five tanks of gas average slightly over 40 mpg. That's with an automatic where the best I could get before trying acetone on this car was 35 mpg. Last fillup I didn't use any additive in the gas and mileage went back down to 35. It works for me and I'll keep using it. So far have used 3 gallons in the past two years in the family's three vehicles and not one problem except better gas mileage.
jamescartagena is offline   Reply With Quote
Old 11-09-2006, 08:00 AM   #10
It's great that you're getting good fuel economy, but tank to tank results are not a good basis to authoritatively assert that something "works" or not. There are simply too many variables at play.
I've also yet to see a properly controlled test showing beneficial FE effects of acetone.
request: add 3&6 month simple moving averages to the graphs. dudleydog Fuelly Web Support and Community News 2 08-19-2010 01:53 AM
Sort by MPG billcharlton Fuelly Web Support and Community News 2 09-18-2008 04:00 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 01:18 PM
o2 sensor brand durability? n0rt0npr0 Transmissions and Running Gear 13 05-05-2006 01:54 PM
