Amsoil 2 Cycle As Fuel Additive - Page 2 - Fuelly Forums
Old 12-09-2008, 02:44 AM   #11
Originally Posted by GasUser View Post
If it really did something or was needed, it would be included in the fueling instructions of your vehicle owners manual.
By that logic, this website should not exist. All we talk about here is ways to do things differently from what the vehicle owner's manuals and state drivers manuals say. If we didn't, you could just read the manual and not have to come here for oddball ideas.
I am still highly skeptical of 2 cycle oil as an additive, and more so of expensive synthetic 2 cycle oil. Jetta90GL's point about fouling the spark plugs is a worthy consideration, too.
Old 12-14-2008, 02:20 PM   #12
yea any time oil gets near a 4 stroke spark plug has never been a pleasent experience in my book
Old 12-15-2008, 11:34 AM   #13
That depends on the heat range. If the plug is running where it should be to begin with there shouldn't be a problem with the 2 cycle oil in the gas. If you've stepped colder a range or two you might see fouling.
And even if you do foul a plug you just go one step hotter and keep motoring!
- Kyle
Old 12-15-2008, 12:47 PM   #14
Expensive vs cheap 2 cycle oil...
The more expensive 2 cycle oils are designed for high(er) dollar performance 2 stroke motors such as outboards, which these days have electronic sensors, some even have cats, so the oil needs to burn totally ashless and provide cylinder lubrication down to 200:1 dilution levels.
The cheaper stuff is designed for cheap motors, weedwhackers, mowers, chainsaws with no electronics or pollution control, and they usually actually NEED some ash content as solid surface lube to keep the rings from sticking up. So the oil is by design, rather dirty, to keep these lower spec motors buzzing.
If you're gonna stick any 2 stroke oil in your tank, find one that meets TC-W3 or TC-W4 specs, which should be ashless and sensor safe. Do not put utility motor 2 stroke oil in it.
Old 12-16-2008, 05:23 AM   #15
Yeah what RW said! BTW 2.5 CC is two point two cubic centimeters to 10 gallons of gasoline - a very small amount and the synthetic oil adds some lubrication to the fuel system moving parts. When used in 2 stroke motors at higher concentrations it comes out the exhaust as oil barely burning at all according to my motorcycle mechanice brother.
Old 12-16-2008, 12:41 PM   #16
VERY preliminary report on the 2 cycle as an additive...
i'm reporting now before the first fillup because i'm taking a couple of days off which will throw off the #s a bit. my driving habits are perfect for testing with exception of extended time off from work.
same route, nearly identical mileage, same relative weather(fluctuates only ~30 degrees, 90% of the time), same avg speed, etc.
anyway, scangauge shows very little increase in MPG so far, and i haven't done any day off(city driving) errands yet(leading me to believe no noteable difference). i'll try again next tank when typical tank status resumes.
Old 12-16-2008, 02:00 PM   #17
I was getting some gains in combo with methanol in Marvin, but didn't seem to do anything at all on it's own. Needed about 2oz TC-W3 with 8oz methanol to 10 gallons. I was figuring it wasn't the lubrication, it was some additive in the TC-W3 that was catalyzing a reaction with the methanol.
Old 12-16-2008, 02:53 PM   #18
my reliable source seems to believe it may be the lube AND cleaning affect that synthetics are known for.
i THOUGHT i heard reported increases of 10%+, but it may have been in an unclean engine/injectors.
Old 12-17-2008, 06:42 PM   #19
Originally Posted by bowtieguy View Post
heard recently about using this http://www.amsoil.com/storefront/ato.aspx as a fuel additive.
the recommended amount was said to be 2oz to 5 gal.
thoughts?
I sometimes throw some old premix in my car. Especially when prices are up. I have used that Amsoil stuff before also. Never gave it much thought. Its MADE to burn in an engine. Maybe not too good for modern sensors like the O2....
Old 12-17-2008, 06:44 PM   #20
I've logged mileage for 1.5 years now. Iv thrown some 2-stroke lube in there, and some acetone, and MMO. Nothing has made any notable difference in my mileage. As always YMMV!
Article about the site on Boing Boing Gadgets. Honad General Fuel Topics 3 08-21-2008 11:18 PM
