Anyone run straight coolant? - Fuelly Forums
Old 03-21-2008, 08:04 PM   #1
Anyone here running straight coolant?
I read that water cools better but you cant use pure water because theres no corrosion protection.
So if running hot is better why not just run straight coolant?
Will it get too hot running straight coolant? I'll probably try it out. I think the coolant in my 94 Metro is original anyway so one day when I have some extra time I'll try straight coolant.
1994 Geo Metro
1998 Buick Regal GS
1999 Chevrolet C2500
1998 Corvette
Three6Eight is offline   Reply With Quote
Old 03-21-2008, 08:11 PM   #2
Ok I just read that straight coolant will gel up, Whats the absolute minimum amount of distilled water I should add?
1994 Geo Metro
1998 Buick Regal GS
1998 Corvette
Old 03-22-2008, 12:08 AM   #3
really...
lol why use distilled water? i just use whatever comes outa the garden hose...
also cant use pure water cuz it would probably boil in todays cars, freeze in the winter, and yes no corrosion protection.
if your wantign to run hot for some reason just use tape over the front of the radiator, if you cant get air to move between the fins to cool it then walla! it wont cool
just put in the correct ammount of coolant and water ratio per your cimate.
Old 03-22-2008, 12:36 AM   #4
fowljesse's Avatar
Distilled water decreases corrosion in cars that have differing metals in their cooling system. I always put it in my cars.
fowljesse is offline   Reply With Quote
Old 03-22-2008, 12:42 AM   #5
Running straight coolant will actually lower your car's overheating / freezing prevention ability, the water is an absolutely essential part of the mix, with pure antifreeze it's almost as bad as running straight water believe it or not.
It may seem like straight coolant would be the best thing, but oddly enough it isn't.
And yes, I called Prestone years ago about this because it didn't make sense to me either, but that's how it is, water is needed to get the protection.
Just run what they recommend and be done with it.
Correct
I always mix it 50-50, that way it's easy.
Old 03-22-2008, 01:31 AM   #6
Site Team
I have a car that I only use in the summer. Therefore on this car, freeze protection is not necessary.
This engine creates a lot of heat, therefore I need maximum overheat protection.
In this car I run zero antifreeze. In order to run without antifreeze, I add about 8 oz of RMI-25 which provides corrosion protection, lubrication to the water pump, etc., which is normally done by the antifreeze.
Pure water has higher thermal conductivity than then antifreeze mix. However, if you run your engine hot (~195) then there is the possibility that you'll get steam pockets which will really reduce thermal conductivity. Since I run this engine colder (~160 - 170), it is cold enough to run the pure water.
But remember that for optimum gas mileage, generally you want the engine to run hot for best efficiency.
-BC
Old 03-22-2008, 05:35 AM   #7
holypaulie's Avatar
I have in my cooling system 70% water/30% coolant + water wetter (corrosion protection) for the best cooling efficiency.
Old 03-22-2008, 05:52 AM   #8
if you run straight water the radiator is going to rust inside
civic94 is offline   Reply With Quote
Old 03-22-2008, 07:40 AM   #9
Use the proper coolant in the proper ratio with distilled water. It comes pre-mixed. This will protect your cooling system, head gasket, etc. which are not a cheap hobby to fix, repairs of which will eat up whatever fuel you may be saving, for the next decade or two.
Water Wetter is an additive that improves heat transfer of coolant. Add to coolant and your fan will have to work less, saving a bit on fuel.
GasSavers_Otto is offline   Reply With Quote
Old 03-22-2008, 09:58 AM   #10
Anyone know where you can get the original "Water Wetter"?
Not the stuff they sell now days, the EPA made them change the formula and now it is not near as useful.
Drag Limited is offline   Reply With Quote
km/l possible? Scottrates Fuelly Web Support and Community News 4 10-05-2010 10:14 PM
Location filter? BDC Fuelly Web Support and Community News 11 09-05-2009 01:16 AM
Hello World! pb Fuelly Web Support and Community News 5 08-08-2008 01:29 AM
How well would a de-hybridized Insight peform (FE wise)? MetroMPG General Fuel Topics 21 10-10-2006 03:33 PM
I issue a challenge!!! Matt Timion General Discussion (Off-Topic) 32 01-29-2006 05:28 PM
