Hf transmission swap into a VX - Fuelly Forums
Old 02-20-2011, 07:50 AM   #1
vxdude's Avatar
Send a message via Yahoo to vxdude
I was wondering has any done this, found plenty of folks that has taken their HF and put a D15z1, What about the other way around? Taking the Federal Hf Transmission and putting it into the VX.
vxdude is offline   Reply With Quote
Old 02-20-2011, 11:53 AM   #2
GasSavers_Erik's Avatar
Re: Hf transmission swap into a VX
It is a good idea- the HF trans has taller gearing so it would likely get better mpg.
Is there a minimum rpm for for the VX lean burn to work?
Old 02-20-2011, 03:35 PM   #3
silversol's Avatar
It will not work! The hf trans has a diffrent mount, cable operated speedo,and a cable operated clutch. All oposite of the vx
Old 02-20-2011, 06:45 PM   #4
vxdude's Avatar
How do people put in a D15Z1 in an HF with a hf trans?
Old 02-21-2011, 05:35 AM   #5
Even with the differences silversol mentioned, it would be possible- just not easy.
Clutch activation- There are kits to adapt from cable to hydraulic clutch, I assume you could go the other way as well (or even make one yourself).
Speedometer- You would have to get a VSS (vehicle speed sensor) signal off the HF trans that your VX ECU could use. Many of the last cable driven honda speedometers had a VSS embedded in the dash gauge cluster- maybe you could rip one apart and have the HF spedo cable drive that component somewhere under the hood.
Trans mount- this might have to be custom made. If you have some welding skills, it is not too difficult. When I converted my civic from manual trans to auto trans, I just bought the trans and accessories a junkyard. I didn't know that the tranny mounts were different until I got the trans in, so I had to spend a few hours making my own trans mount.
Now if the bell housing bolt patterns are different, that would be a much bigger problem...
Old 02-24-2011, 08:32 PM   #6
imzjustplayin's Avatar
Even easier, the OP could get a VSS from a newer '92+ transmission and it drops right into where the cable driven vehicle speed sensor goes on the cable transmission. True plug and play in this instance!
I don't know about this, I think the mounts should be the same since there really isn't all that big of a difference between the cable and hydro trannys. I hear of people using cable trannys with hydro engines all the time.
Old 02-24-2011, 08:34 PM   #7
OP, if you're wanting to do this swap because of your unexciting fuel economy you're getting, I think a better question to ask is, the 45mpg you're getting, is that with or without hypermiling? You should be able to do better than 45mpg assuming you're not ragging on your car..
Old 11-13-2012, 06:37 PM   #8
They bolt together there is no conversion kit and good luck with parts. However I think the way to do it is to have the gears installed into your case. I believe they are interchangeable. More$ but probably much less headache and Mickey rigging. My 2 cents.
Rusty94cx is offline   Reply With Quote
Iron/Aluminum block? GasSavers_Shrek General Fuel Topics 18 03-30-2009 06:34 PM
who's using these? results? collegekid01 General Fuel Topics 7 07-10-2008 09:11 AM
honda ascot milage gains... Philip1 Motorcycles 9 06-16-2008 03:08 PM
What are your shifting patterns??? Compaq888 Hypermiling 13 08-22-2006 06:41 PM
