i want to make my own Map/Maf enhancer - Fuelly Forums
Old 11-07-2008, 07:40 PM   #1
hello ive search the net like a bot looking for instructions on how to make a Map/Maf enhancer and i cant find anything. well if someone can help me with some detailed instructions on how to make one and install it would be very appreciated i work at radioshack so i know all the parts are their but i dont know how to make it
Mark_alot is offline   Reply With Quote
Old 11-08-2008, 05:42 AM   #2
Not sure what you mean by "enhancer". Do you mean an EFIE? What are you trying to accomplish? Jim
dutchdivco is offline   Reply With Quote
Old 11-08-2008, 05:53 AM   #3
GasSavers_Erik's Avatar
He wants to change the electrical signal from the manifold air pressure sensor (or mass airflow sensor) so that the computer thinks there is less air entering the engine- the computer would then inject less fuel (leaner mix) which could increase mpg.
EFIE's increase voltage to the oxygen sensor signal so the computer thinks the engine is running rich and leans the mix out- same principle (leaner mix) but different set of sensors (exhaust gas sensor).
Markalot- It seems like you could just use a dial type resistor on the output side of the map/maf sensor
http://easywatercar.com/kayakosuppor...id=131&nav=0,1
Note: I am a hydrogen skeptic, but I believe the HHO folks do know how to lean their mixes (in my opinion this is what causes their increases in mpg)
Old 11-08-2008, 05:58 AM   #4
Here's an installation guide telling you what wires to splice into:
http://www.3rdbrakeflasher.com/docum...AP_Install.pdf
Old 11-08-2008, 09:10 AM   #5
I have a schematic for a MAP/MAF sensor enhancer. If you'll PM me your e-mail address I'll send it to you.
Hipermiler
#47 on my way to #1
Old 11-08-2008, 09:24 AM   #6
if you want a quick easy solution go to radio shack and get a volume control nob and splice it map/maf sensor...cost 5$...u can control the voltage which controls the ratio by turn of the knob...as far as where to splice i go to autozone.com and then to repair guides...thats all i use on my 04 jeep wj..
hope this helps...my gains are consistent...heres a vid of where i put mine..
http://www.youtube.com/watch?v=r32Xyl7sJLQ
hope this helps
horsepower tv on spike just announced upcoming hho project on tv ..bout time!!
good luck..peace out!
s15w350 is offline   Reply With Quote
Old 11-08-2008, 07:42 PM   #7
thats what im thinking.
Old 11-09-2008, 05:59 AM   #8
I think this link will help you out.
http://www.hhoencyclopedia.com/hho/d...0schematic.pdf
2005 Dodge ram 1500 5.7 Hemi quadcab 4x4
9"x9"- 7-plate Tero cell 5.5 LPM @58 amps 6.72 MMW
10K IAT,6.8K ECT mods,map enhancer and 2-dual efies for both pre and post cats,custom 12o amp constant current PWM ZFF's v2 design
Come check out the HHOscambusters forum
https://pmgen.com/hhoscambusters/
hyknowledge is offline   Reply With Quote
Old 11-09-2008, 01:50 PM   #9
thank you alot. what are the consequences of long term leaning out if your not hooking it up to a hho system.
Old 11-10-2008, 12:39 AM   #10
Most likely you won't have to worry about any consequences from leaning or overleaning using only a map enhancer.Depending on what year and vehicle you have the ECM wil look at the O2s last before making it's final decision regarding air fuel ratios(AFR).Using only a map enhancer most likely will cause at most constant check engine lights due to ECM sensing the offbalance between the map and O2 sensor.
To have any sucess in trying to lean the AFR you'll probably have to install an O2 efie as well and use the two together to achieve any AFR leaning.Remember the ECM will always strive to maintain the 14.7:1 AFR it was designed to do,and any attempts to lean the AFR should be done in small tweaks so as not get caught by the ECM as to what you're up to.Following each small ajustment you should drive the vehicle for a day or two and monitor for any problems and allow for the system to accept(if it does accept) the changes you've made before making any further ajustments.If you go too fast it will only take longer to complete the adjustment process.
Hope this helps let me know if you need more.
Rusty
Decided to grab the bull by the horns, gettin' a scooter Rayme General Fuel Topics 34 06-16-2008 07:28 PM
hello Im new 90accord Introduce Yourself - New member Welcome 1 05-13-2008 10:04 PM
I got an EV! lovemysan Electric and Solar powered 14 11-17-2007 07:55 PM
93 civic vx d15z vtec 1.5 engine tranny ecu 112,000 miles. - $200 McPatrick For Sale 5 07-24-2007 02:20 PM
ford ranger fredro Introduce Yourself - New member Welcome 6 11-10-2006 07:43 PM
