I recently got back into soldering since I was back in highschool a/c refrigeration course and thought this might be of some use to you do it yourselfers here. Enjoy http://fordfuelinjection.com/?p=7
Thanks, I printed it out. I had never seen an "inline" connection like that before. I have become a recent fan of heat shrink tubing because it makes everything look so clean and professional.
I've used that sort of connection before: it works well for any stranded wire that you'd want to solder.
One place to get the adhesive heat-shrink tubing is Waytek Wire. They're usually cheaper than other places, and have a nice selection of automotive-type electrics.
Thanks Civic for posting, this will help out on my future projects allot!!!
i use the ol solder then wrap in electrical tape if its in the car. if its under the hood i either use crimp on connectors or very rarely heatshrink tubing...havent had a problem yet. but they all do the same thing: connect wires. so it doesnt matter what you do as long as its insulated and make sa good connection
