09-28-2009, 07:57 AM
Even if you could implement a simple switch I wouldn't recommend it in an emissions state. IACs are usually a stepper of some sort so a single switch won't work the majority of the time anyways.
The high idle in a manual transmission car is most likely because the manufacturer just took the auto transmission program and flashed it to the manual ECU sans auto trans code.
The reason it is in there for the automatic has to do with transmission safety. Only my Cressida did the high idle when coasting thing and that car couldn't be flat towed. The Tracker would drop to a normal idle at 70 when I put it into neutral and so does the Durango. Both cars are safe to flat tow.
It's likely that if the engine speed isn't high enough in some cars that there isn't enough to keep the bearings pressurized where they need to be. The following is a list of vehicles safe for flat towing. If your car isn't on the list it's likely that you'll have a high idle in neutral.
Cars
Chevrolet
Cavalier Coupe & Sedan
Malibu
Daimler-Chrysler
Neon
PT Cruiser
Sebring/GTC
Stratus Coupe
Ford
Focus
Mustang
ZX2
Hyundai
Accent
Elantra
Sonata
Tiburon
Nissan
350Z
Altima 2.5
Maxima
Sentra
Oldsmobile
Alero GX Coupe
Pontiac
GrandAm SE
Sunfire
Vibe
Saturn
ION Sedan
L-Series
Subaru
Impreza 2.5 Sedan & Wagon
Legacy L & Wagon Versions
Outback Sport
WRX & Wagon Versions
Suzuki
Aerio S/GS Sedan & SX Wagon
Toyota
Camry LE
Celica GT & GT-S
Corolla CE
Echo
Matrix 2WD
MR2
SUVs & Pickups
Acura
MDX
Chevrolet
Avalanche
Blazer 2DR 4WD
Envoy/Trailblazer 4WD
Silverado/Sierra 1500 Series 4WD
Suburban/Yukon XL 4WD
Tahoe/Yukon 4WD
Tracker 4WD
Dodge
Dakota 4WD
Durango 4WD
Ram 4WD
Ford
Escape 2WD & 4WD
Explorer
F-150 4WD
F-250/350 SD 4WD
Ranger 2WD & 4WD
Honda
CR-V
Element
Pilot
Hummer
H2
Hyundai
Santa Fe FWD
Isuzu
Ascender 4WD
Jeep
Liberty 4WD
Grand Cherokee 4WD
Wrangler
Land Rover
Discovery 4.6
Range Rover
Mazda
B-Series 2WD & 4WD
Tribute DX FWD
Nissan
Frontier 2WD & 4WD
Pathfinder SE 4WD
Xterra 4WD
Saturn
VUE
Subaru
Baja
Forester 2.5X
Outback Wagon
Suzuki
Vitara & Grand Vitara 4WD
XL-7 4WD
Toyota
RAV4 2WD & 4WD
If your car isn't on the list, check the owner's manual. If you have a 2wd version of the 4wd listed check the manual as well. Anything about only towing the drive wheels at a low speed and/or a short distance you probably have a high idle in neutral coasting.
- Kyle
09-28-2009, 08:07 AM
Originally Posted by spotaneagle
its to keep the synchros in your transmission from wearing out when re-engaging in gear, the closer your rpms are to the speed it will be in gear, the less wear when reengaging, there's a technique to downshift where you rev the rpms to the speed the lower gear will be at when engaging the clutch, it's called rev-matching
my point is, if you understand rev-matching, you can theoretically use a switch, or something, to lower rpms, then undo the switch before you go back into gear
Where the engine is in relation to road speed shouldn't affect the synchros. If you use the clutch when going back into gear the synchros are only used to pull the clutch up to road speed before you use the clutch to bring the engine up to speed.
- Kyle
09-28-2009, 09:25 AM
That list is inaccurate, unless it stipulates that the engine must be running. Where did you get it?
I'll double check the manual, but I'm pretty sure that my Silverado/Sierra 1500 Series 4WD doesn't allow flat towing, even with the transfer case in neutral.
09-28-2009, 09:42 AM
I got the list from an RV information site. Won't let you flat tow with the tcase in neutral?
- Kyle
09-28-2009, 09:52 AM
I believe K series GM trucks are flat towable, but not with the electronic transfer case, only with the manual transfer case.
09-28-2009, 04:26 PM
Tomorrow night I'll have to remember to check my manual.
09-28-2009, 05:31 PM
Banned
dk jones lied, cow's transmission died
09-29-2009, 03:11 PM
I never tried it, and I'd recommend everyone confirm that their particular vehicle, as equipped, is good to go before doing it...
12-04-2009, 07:43 AM
#19
back from the grave...
My little stick shift Metro did the same thing. Found out that the speed sensor was keeping the RPMs high in order to make shifting easier. Once the car came to a complete stop, the idle dropped to factory specs.
I "solved" this by disconnecting the IAC electrical connector. I can now neutral coast at factory idle.
12-04-2009, 11:44 PM
#20
Banned
all u need is a console mounted on off switch shizamm!
