Solar/plug-in 12V system, alternator optional - Page 2 - Fuelly Forums
Old 09-20-2006, 05:51 PM   #11
JanGeo's Avatar
Aside from the belt load which may not return enough to bother with long term because you WILL need electric power at some point. The simplest solution that is non-invasive is to supply power to the electrical system from another power source i.e. solar panels and an additional power regulator from another battery. If the car battery is supplied current that keeps it about the 14.x voltage the alternator will stay "off" and not load the engine and the car battery stays fully charged and will not have it's life shortened by cycling. The additional battery will provide power until you want to regen down hill charge it from the alternator then you just load down the system and charge the extra battery or charge it from the solar and/or grid when you stop and park. This will also allow you to run accessories longer without the engine running like when you are coasting with the engine off while maintaining full system voltage for brighter headlights.
More detail josh434 General Fuel Topics 2 06-28-2009 02:39 AM
Article about the site on Boing Boing Gadgets. Honad General Fuel Topics 3 08-21-2008 11:18 PM
E85 - 85% Ethanol 15% Gasoline JanGeo Vegetable Oil and BioDiesel 30 06-29-2008 05:33 AM
Altima aerodynamics Compaq888 Aerodynamics 21 06-22-2006 08:57 AM
