Re: Question about car warming up from a newbie
Hey Guys,
Thanks for helpful opinions. BE350 |
Plus, driving it warms the entire drivetrain and not just the engine. Your 02 sensors will go to closed loop faster leaning out the fuel burn. Once your entire drivetrain (and fluids) are at normal running temps, you will get the best fuel economy too. Just some additional thoughts. |
Same as everyone else has said. I'm up here in the Antelope Valley, still LA County, but we do know what cold is somewhat.
Summer time, get in and drive. Winter time, get in and drive, but don't need to turn on the A/C. |
Ditto. If the engine's running, it should be doing work. Otherwise, you're wasting fuel and money.
One thing I won't do is run the air at all until I'm actually out of the road for a minute or two, if its needed otherwise just vent. I usually just crack both front windows as long as I'm in stop and go at first, but as soon as it can be done I'll typically just turn my vent on low.
Cold meaning below freezing, not when you might want a windbreaker on.
BTW, I think autostarts should be made illegal. They lead to widespread idling abuse. :mad: |
Start the car and drive the only time I do not do that is when I have to clear the snow and ice from my car.
NEVER LEAVE A CAR RUNNING IN A GARAGE! Look up carbon-monoxide poisoning and remember just because it does not kill you right away it does build up in your body. |
