So your exhaust was smelling
So your exhaust was smelling bad? Like what?
Haha, not my exhaust, my
Haha, not my exhaust, my engine through the air vents. Smelled like melting plastic, which makes sense since that's what it was. :-)
Gotcha.
Gotcha.:D
ElectroMagnet
I've seen these magnets on the fuel lines of limos and town cars that are driven hundreds of miles a day. However, the logic behind them escapes me.
Is gasoline magnetic? If the idea is to effect some change in the gas while it's passing through the magnetic field, shouldn't the magnetic field's strength change with the volume of gas being passed though it? Using permanent magnets seems like a waste since they become weaker when heated(like under the hood hot) and stop when banged about, like when swinging about banging around between hoses. Ideally the magnet should be an electro magnet with the voltage going to the core of wire wrapping varying directly with the speed of the fuel pump. Also electro magnets are way stronger than permanent magnets, and as cheap as a spool of wire, and a few zip ties. |
Alright you guys, I realize that I'm and old fart but I experimented with magnets and carbureted engines 25 years ago. I got fantistic results. I used a 1980 GMC 4X4. It had a 350CI with an auto trans. Obviously not a gas saver. I hooked up a 1 quart container to the fuel pump. I carefully measured the distance while trying to conserve fuel. I added 1 cow magnet and increased the distance by 6 blocks. Added 2 magnets and added more distance. With 3 magnets all faced the same direction I got an extra mile. I still don't know what effected the gasoline but it works.
I'm doubtful, for too many reasons to list.
A good place to start: https://fuelsaving.info/magnets.htm |
Hi HOTROD -
I didn't know about cow magnets until you mentioned them. Were they the "big solid pill kind", maybe 4" long? How did you attach them? CarloSW2 |
Check the science behind it , it just doesn't work. Liquids and gasses cannot be magnetized - period (unless its quicksilver , but then thats a molten metal). People have been wanting some magical effect from magnets for hundreds of years , and if you research it back , you will find many claims and applications that magnets do this or that ,, and even improve your health. Yes , even those people that wear magnetic undersoles in the shoes or wear special belts around various parts of their body have been duped. If magnetism was beneficial for your health then I must be the most healthy person in the world as I get an MRI (magnetic resonance imaging) scan every 6 months. During this I get exposed to more magnetic radiation than anyone could achieve with those medicine magnets. But am, I healthy ,...NO ! It is all scams , It is all scams -- do your homework first before you buy anything., but best idea of all , forget magnets. |
Your too late , it was done in the '20's by Snub Pollard https://www.corbismotion.com/Popups/V...2-162b772919ee Or download the footage at: https://www.corbismotion.com/video/C057/C057_2_5_1.mov |
For me the best use of magnets is to put one in the pan on my auto tranny, also one on my oil filter. this keeps all the magnetic metal particles stuck in one place, instead of floating around where they can do damage.
