GasSavers_Phoenix |
05-08-2007 03:24 PM |
Yeah, electric heat is not even concievable in my area, even with domestic hot water, you basiclly just do it grudgingly out of nessecity (no gas line near a rural home for instance) Unforutnately solar isn't quite as sexy an option here as it is down your way, but still viable.
Originally Posted by trebuchet03
(Post 50570)
Then again... I still like my parent's water tank system.... It's a solar feed heat system... Takes in "warm" water from the tank - passes through a solar panel -- feeds back into the tank. All powered by a PV panel/pump. The tank never turns on during the day. Now if I could convince them to put it on a timer to shut off at night...
Does that system use a heat exchanger?
