Re: CD
have a look at the spreadsheet or the web page and you'll see the aero penalty begins to rear its ugly head relative to rolling resistance at between 30-35 MPH. https://metrompg.com/tool-aero-rr.htm below that speed you burn most of your fuel to overcome rolling & mechanical drag. above 35 mph, you burn most of your fuel fighting a losing battle against aerodynamic drag. (a "losing" battle because the amount of fuel needed to overcome aero drag quadruples as speed doubles.) |
YEs you hAvE
Yes you have misunderstood - the drag coefficient is the factor of the streamlineness of the shape i.e. square box vs teardrop but that has only a small influence on the aerodynamic drag - the more important factors are frontal area first and rolling resistance due to weight second. This is why the really fast sportcars are very small and low to the ground, pointy or not they only go fast because of their small frontal area and a few extra HP as well of course. Once you get up over 150mph then the shape becomes more important as well as surface treatment.
Re: YEs you hAvE
I am taking a statistics
I am taking a statistics class in college right now. I think you guys could teach the class.
drag drag drag
Apparently the equations are not as simple as one is led to believe according to one site I found. I will have to go back to my college days when I modeled hp vs speed for cars and got some good results with a basic equation. Found some Cd for various cars on line also.
referring to the classic equation . . . https://hypertextbook.com/physics/matter/drag/ R = .5 Cd roe A v^2 "Simple, compact, wonderful. A nice equation to work with -- or is it? Well, yes and no. Yes, but it works only as long as the range of conditions examined is "small". That is, no large variations in speed, viscosity, or crazy angles of attack. The way around this is to reduce the coefficient of drag to a variable rather than a constant. (I can live with this.) Cd depends on some yet to be specified set of factors. It is totally acceptable to say that Cd varies with this that or the other quantity according to any set of rules determined by experiment. No, since speed is squared. [Gasp!] Recall that speed is the derivative of distance with respect to time. Have you ever tried to solve a nonlinear differential equation? No? Well, welcome to hell. Wait, let me rephrase that -- Welcome to Hell! [Ca-rack! Boom!] Ah ha ha ha ha haaaa! [Rumble] You fool! No one can manage the square of a derivative. The mathematics will consume you. [Ca-rack! Boom!] Ah ha ha ha ha haaaa! [Rumble] Whew. What the hell wasthat all about? I might not know how to solve every kind of differential equation off the top of my head, but so what. I can always look for the solution in a book of standard mathematical tables or an on-line equivalent." |
Re: drag drag drag
so we're left considering the writer's concern over the "large variation" of speed. and with no definition of what a "large variation" is, it's not a particularly useful point to have raised. (is 30-70 mph through air considered a "large variation"?) i don't think the utility of the equation is seriously in doubt for the application we're looking at. |
Re: CD
back to college
I will get the old punch cards out of the box from my college days and bring in the equation that I used for my Rambler which pretty much nailed my top speed dead on. It took into effect weight frontal area and drag cooefficient and yields either HP or speed in MPH.
punch cards!! i caught the
punch cards!! i caught the very tail end of the punch card era:
my very first computer class in high school was about the last year it used cards (the pencil-in-the-boxes kind). at that time my "PC" was a Commodore 64 :) yes, if you can decipher the cards, i'd be interested in seeing another version of the equation. |
Results look good...
I did a spreasheet a week or so ago that does essentially the same calculation and my results agree with yours. ~40mph is the point where rolling resistance becomes secondary and air resistance takes over. This also agrees with my informal observations with the scangauge. On a nice flat road I can get some really crazy instantaneous FE numbers when I'm driving between 35 and maybe 42mph, 35mph being the slowest I can reasonably cruise in fifth gear. After that my numbers decrease from 40-50mpg+ to the high thirties and down.
