GasSavers_Hal9000 |
04-13-2009 08:09 AM |
Originally Posted by bobski
(Post 132291)
I'm saying, take the metal plate (the one with the PGMFI label on it) off the air chamber above the throttle body opening, and cover the port that the flexible tube draws air from, rather than trying to pinch off the tube or something.
Yeah, I figured that out after leaving the site. Just didn't come back to edit things.
(Post 132291)
How do those two clauses indicate anything else? My statement followed the pattern "If... If not..."
If the engine stalls, the IACV is bad... If the engine doesn't stall, then there's a vacuum leak.... What would the engine do if nothing is wrong? See what I'm saying. With only two options, an engine with nothing wrong will have to do at least one of them....
The engine stalled by the way (although in retrospect, I don't think I unplugged the IACV before I checked). Maybe the IACV is bad, but we bench tested it last week and the actuator motor responds to voltage perfectly, and the current draw is smooth and consistent on the oscilliscope as the plunger moves back and forth. Also, with the throttle plate completely closed, I can't see how blocking all the major intake air to the engine (via blocking the IACV tube) would cause anything but a stall in any circumstances. Maybe I'm missing something vital, but everything sure looks like it checks out to me.
Anyway, over the last week or so, I've replaced/readjusted the TPS, Added an additional return spring to be sure the throttle is closing that last few fractions, readjusted the idle, and reset the ecu several times. None of those things made any huge difference on their own, but the accumulated effect has been that the fast idle on startup is down to a consistent 1500 rpm, and it eventually drops to between 700 and 950 rpm. It still pulses a little occasionally, but not like it was. If it's not steady at 7-800, then it'll only bounce by about 150 rpm or so and not get up over 1000 rpm. Considering how it was, that's a major improvement. I'm going to drive it for a few days to see if it stays that way.
