Re: USA-centric
It was programmed for Japanese Prius and I tried to be optimized, effective and fast results for km/L. Please try to acknowledge/understand the international SI units standard. :) Yoshi |
Re: USA-centric
Re: SuperMID Up and Running
One minor correction. The % value is not % time but % distance. So, your taget is 27% distance the engine running as same as the 1400 mile marathon, right? :) Yoshi |
you'll get used to it, matt.
you'll get used to it, matt. i did :) - before i got the scangauge, i never used to "think" in mpg (US).
but after having learned my mpg (US) "targets", as dan pointed out, i stopped worrying about it. to me it doesn't matter if the thing reports Kanseis per Farfegnugens as long as it's accurate and consistent. it's my "target" points and the relative differences between them that interest me most. the only time i really like to have control of units is when running tests, when i select "km/gal (US)" output. nobody ever uses those units in real life, but it's where the SG offers the highest resolution for comparing readings. (i'm nit-picking, admittedly). |
Perhaps a little calibration is in order. I was guessing 55 MPG on the way to work and 47 on the way home, 51 average. This would correlate well with the typcal prius commute. |
Re: you'll get used to it, matt.
Re: How does it work so that
If this was sold for like a $100 I'd be all over it. Maybe we can do a group buy? |
but i kind of suspect that this feature isn't included on cars with automatic transmissions. if your fuel supply were shut off, wouldn't your motor would stop running (unless your torque converter was locked)? *maybe* there's enough pressure in the torque converter (unlocked) above a certain rpm to keep the motor turning. i'm not certain. in a manual shift car, the momentum of the vehicle through the direct connection of the wheels, tranny, and motor keeps the motor spinning, even when the fuel is off. when the rpm drops low enough that the engine is about to fall below idle rpm, the injectors start supplying fuel again. i could be wrong on the auto trans thing. just a guess. |
Also would this mpg computer work with 0bd2?? |
