searching...
Well I couldn't communicate with the e-bay seller that had the wiring harness and ecu, but I couldn't get in contact with him. I dont know if I should continue on e-bay or go to honda-tech. I dont really know what the parts should be worth so that is making it a little difficult. What should a d16y5 cylinder head be worth anyway?
Re: searching...
The gas mileage engine parts don't have a very high demand, so you might want to lurk on honda-tech and post a few WTB ads. You can probably get it for around $50. I think you can find an ECU for around $30-40. Once again, the low demand forces the price way down. |
Alright, Do you think I
Alright, Do you think I should stick with buying a new 5 wire O2 sensor? I think that would be the best even though that will be a pretty penny.
Re: Alright, Do you think I
I say to get it running first, and then worry about the little stuff. |
once you have the stock
once you have the stock connector for the o2 sensor i believe you can buy the ntk wideband replacement sensors from any source and just change over the pins...should be the L1H1 sensor available from any wideband/tuning distributor...
I've found it's worth
I've found it's worth checking www.car-parts.com when looking for parts, they are sometimes a bit more then Ebay, but also tend to be local so you save on shipping.
One of the links matt posted
One of the links matt posted about the vx head is selling a 5 wire o2 sensor.
I would not put a universal bosch type on a honda. |
link..
Where is that link at? I mise well start looking for parts. I want this swap finished by June 15th. (I should have 150k miles on the civic by then...
did i say bosch
did i say bosch universal..????
no i believe i said NTK L1H1 ... |
Quote:did i say bosch
