smokin the tires have little to do with HP... all about gearing. also back then cars had pretty narrow tires compared to nowadays cars of equal sizes.
Make no doubt, I will enjoy money. It must be moved from one stream in the economic structure to another stream to get that done. That is the way things work. How many hours...blood sweat and tears have people invested in the existing operating parameters after buying the vehicles? for decades? Many improvements have been made...but never mainstreamed. Ergo my freedom ofchoices have been taken away from me. Always in the control of the huge corporations. The same, or less, efforts put forth by the tinkerers/backyard scientists/etc etc etc ...will only speed up the transition get to mainstream. AT THE BEGINNING STAGES !!! I was given 6 months to live, by 6 competent doctors, and until "an accidental intervention" they were correct. I know how to reverse carpal tunnel syndrome...no surgery...medical fact... documented by a surgeon of 25 years standing...medical history. I defined the reverse points of 10 previously thought "irreversible medical conditions"...so far they are reversible. The information did not exist for them to use until that moment in time. I have defied odds that would make the bookies in Las Vegas cringe !! That was 3 years ago... this system is to be my legacy. It was designed when I was convinced I did not have many tommorrows...I do not know if I will have many tommorrows? a peculiar mindset; of loss of fears; normally people would cater to those fears. After what I have been through...survived...time has a different set of values for me...not based on the monetary exchange system. Am I a wealthy man? No. Will I be a wealthy man...hope to be. I used up most of my wealth to stay alive...got to look at my money and knew it was useless for me at the time... I had excellent medical insurance at the time of my sufferage. When this technology gets into mainstream...it will extend the known fossil fuel reserves by some 3000 years...maybe more....tommorrows for my decendants. Please appreciate, when I give of my time, it is a very generous thing. Robert |
With lower coolant temps, do the engines experience accelerated cylinder bore wear? Accelerated bearing wear from not as much water not cooked out of the oil (and thus acids being formed)? |
the Ford 8N used the model A engine, poured babbat main bearings, flat tappets, flat head, updraft carb, about a 4:1 compression ratio, ford advertised at 40 hp (modern dyno tests one built exactly to ford specs of back then to 38 but whatever lol) if i remember right has a 2800 rpm rev limit before it blows itself up because the crank is not counter balanced. idle is supposed to be 60 rpm (huge 60 lb flywheel helps that lol)
not sure what the engine is supposed to run at (they never had thermostats) as long as it was under the boiling point of water 212* it was happy. the oil pump makes 1 MAYBE 2 psi, its just designed to pump it up into the valve chamber and then run down to lube the timing gears, valves, and crank mains. the rods were splash oiled from a pan that filled with the oil that ran down from above. my engine that has been sitting from the prolly mid 50's when i cracked it open it had about 3 qts outa 5 left in the pan (among a 1/2 inch to an inch of sludge but id assume that) it would have and still could be run (still cheaper to find a good used block lol) because mice had made a nest on top the piston, completely corroded a few valves off from thier piss. the main and rods are still great (i have pics if anyone would like to see i can make a separate post lol) |
Erick, Decent question. water only gets into oil at higher temps when the vicosity is at its lowest, or molecular structure is at it weakess....emulsion. Low operating temps extend oil changes...haven't found metal particulates yet...in oil I sent to labs. This was after being set up right as can be....cleaned up and all that. Of course that cannot be "possible" ...everything has wear points??? Wait.... that is excessive heat and/or electrolysis when there are wear points...some form of oxidation. You might look up "Smart OIL " on google...it will have articles about shock absorbers that change oil viscocities with electrical pulses. Robert |
ideal cycles
It ain't about the oil companies...totally. It is more about nuke energy staying in the market place...coal energy...to produce electricity. Ford did not create it....they bought it and shelved it...'it' being several designs. So did GM and Chrysler. Almost every design bought up with intimidation tactics. You use gasoline because they tell you to. You should google about wet "hydrous ethanol" and read some of the results that have been found out. State of Louisiana got a waiver from EPA to fleet test wet ethanol. They have to make thier own...for control issues. Just so you might keep up, that is ethanol/gas/water blended for better performance Robert |
Mr. Hull,
I find this topic interesting, but something just doesn't ad up. Why on earth are you posting this. You seen to be scared of people ripping off your idea, maybe overly so, but understandable. So why would you tell us about it, and don't you have meetings with Toyota to get to? I see the ICE as a very dated technology that is coming to an end soon. If your thing, whatever it is, works you would be wise to get it to market as quickly as possible. Getting approval from some wankers, like myself, in not a necessary step. If you where posting because you wanted to share HOW you did this, well that would be great, but you don't seem to be doing that. I just don't get your motivation. Which leads me to believe you a 16 year old in your mothers basement with far too much free time. |
