wow...2k is quote a steal
Thanks compaq888
Great weather to be wrenching today. Got the rear hatch struts replaced in the back, makes life much much easier now than the stupid broom rod. Got a couple of quotes on pulling the dent out. Seems to range from 700-1500 for the thing. Most places don't seem to care that the body is made out of aluminum which worries me a bit. Vacuumed out the inside, found 33 cents in change, an earring, salt shaker, speeding ticket, cancellation of phone service notification and an ATM receipt. Seat sliders badly need some lube. Drivers seat is fairly worn and stained. Going to try steam cleaning them else I was debating replacing them with S2000 seats if I can find them cheap. Windshield will be replaced next week. I don't think $250 installed at my home is too bad of a price. Was attempting to pull out what remains of the old quarter panel window, but the sealant is a pain in the neck to cut through. Going to try to find either a gasket cutter or some sharp blades to cut though it. So far Rommie is starting up fine, SOC hasn't moved much as I've been starting it and moving it around a bit. Granted it hasn't really been used but seems ok. Going to spend tomorrow cleaning out the harness around the front 02 sensor, see if that will patch it up. |
How about some pics of the Insight?? My imagination isn't that good and a picture is worth a thousand words... |
True true, but I have yet to fine a local place that would be willing to do the Honda under $250. Would love to get it lower though. Can't legally drive it or tow it anywhere far.
np, I have some old pictures posted up earlier https://www.gassavers.org/showpost.ph...1&postcount=36 Need to give it a wash and take some new pictures soon. |
In between helping my dad put up the shed I got a couple of things done.
Replaced the front parking light bulbs, now my front emergencies work again. Tiny little things, utterly pointless, but hey it works now. And only cost a buck. Tried to replace the tranny fluid but the fill plug seems like its welded itself to the tranny. Cheater bar didn't help so I've sprayed it with PB and later on I'll put it on stands and see if I can get some better leverage on it. Played with the LAF a bit. According to the ECU & the FSM its slow and non functional, but I'm wondering if its possible to clean it? Figure it worth a shot before I blow 220 bucks on a new one. So far I've heard there are 3 different ways of cleaning one 1) Heating it up with a blow torch then quenching it to knock the carbon loose 2) Spraying the crap out of it with carb cleaner 3) Dunking it in acetone The sensor is physically dirty and apparently there are some kind of vent located on top of the sensor that could get clogged and cause a similar problem. I am going to try to clear the vents first, then pull it out and clean it with something. |
FYI
Insight Central has just upgraded their forum software, and now has a search function that can use all of the standard search delimiters. Much better ability to find stuff. |
That really was quite a steal! I can't wait to see what kind of gas mileage this thing is able to pull off.
IC is still a pain in the arse to find something technical. I don't know if its the nature of the vehicle, but in the Jeep community its cake to find technical component information.
Crap, so cooking it might not work if the sensor is simply worn out. I need spring break........ |
https://www.gnttype.org/techarea/ecms...O2sensors.html
If you are not able to make a change either way, stop the engine, unhook the sensor wire from the computer harness, and reattach your voltmeter to the sensor output wire. Repeat the rich and lean steps. If you can't get the sensor voltage to change, and you have a good sensor and ground connection, try heating it once more. Repeat the rich and lean steps. If still no voltage or fixed voltage, you have a bad sensor. If you are not getting a voltage and the car has been running rich lately, the sensor may be carbon fouled. It is sometimes possible to clean a sensor in the car. Do this by unplugging the sensor harness, warming up the engine, and creating a lean condition at about 2000 rpm for 1 or 2 minutes. Create a big enough vacuum leak so that the engine begins to slow down. The extra heat will clean it off if possible. If not, it was dead anyway, no loss. In either case, fix the cause of the rich mixture and retest. If you don't, the new sensor will fail. |
