white gas
Gents:
Has anyone here tried running straight white gas? With the interest in fuel vaporization and experimenters like Smokey Unic (sp?) having gotten impressive mileage with vaporization setups, and the problems with modern gasoline having some hard-to-evaporate molecular chains, I thought this might be worth trying. Was pre-WW2 gasoline essentially white gas? |
Good questions- how much more does white gas cost per gallon than regular gasoline?
Good old Naptha.
What about just running alcohol? It's cheaper. White gas runs about $6 a gallon to $11 a gallon depending on your source while E85 can run in the $2-3 a gallon range. |
Amoco Ultimate used to be white gas, and they advertised it as such (as recently as ~5 years ago). I don't know with all the new formulations if its still white though.
-Jay |
This question is more of an efficiency persuit than anything else. Cost-wise its much higher than regular gas, and for good reason. I think that white gas was distilled from petrolium.Then came hydrocarbon cracking that permitted about 80% of a barrel of oil to be converted into gasoline, but with a much less pure product as the result. Higher purity= better vaporization? Worth a try I think. Just don't want to damage an engine. Any idea what the octane rating of white gas is?
It's actually a great additive to the fuel if you aren't running close to knock all the time.
I could see a $6 gallon of it from Walmart working wonders for someone. I never hear my car knocking so maybe I should buy one and put a gallon of it into my gas tank on my next fill. Should get me from 86 octane down to about 83.5. |
