turbo vtec-e on 4 dr civic gas mileage
https://www.turbod16.com/viewtopic.ph...0+afr+not+very
currently ive been getting 30-32mpg combined. my commute consist of driving to school 10km highway @80-100km/h then 16km city(more like alley streets here in the philippines) and it roughly takes me 45-60 min to get there, depending on traffic. i think my tires and the transmission thats causing the bad mileage...are they? 2650rpm@62mhp on 195/50/16 dunlop fm901.... |
There's some good advice in the thread you provided.
You have a good motor, good trans, but driving on goat roads while maneuvering around slower traffic obstacles will hurt FE. Like they said in that thread, afr's need to be richer at mid to open throttle. I recomend keeping the afr's very lean at the lightest loads. |
ahh yes i posted that 6 months ago and listend to that they were saying so i increased the fuel a bit
i took the afr to 16.5 light loads to a gradual 14 wot. the mileage went bad from 28mpg to 25mpg now my afr are 18:1 light load...17:1 wot...20:1 cruising and been constantly logging 30-32mpg |
Here's a post I wrote on another forum. I think it applies to your car as well.
How lean you can go depends on how much airflow (grams per rev) is going through the motor. At light load you can go very lean without fear. As airflow goes up the A/F ratio should gradually get richer until around 5 in/hg vacuum where it should be around stoich. From my experience the limit to how lean you can go will be misifires. If the motor misfires, it's too lean. Bigger plug gaps helps to reduce lean misfires, but you'll have to balance that against WOT misfires if the gap is too big. I've been able to run slightly leaner than 18:1 at very light throttle. I also found that my motor doesn't have a smooth idle and it stalls easily if the A/F ratio goes leaner than around 16.0:1. So I've set my rolling idle A/F ratio at 16.0, then it goes to 18.0 just off idle, and gradually richens. A side effect of running leaner than stoich is that the mixture burns slower, so knock is less likely, but the engine needs more timing to keep power levels from dropping, so I've also added one or two degrees of timing in the same parts of the map that are very lean. It's working very well! There's some good info in this link. https://www.max-boost.co.uk/max-boost...ion_deeper.htm Scroll down to the bottom, there's a little chart that shows mixture burn speed at different A/F ratios. It'll give you an idea of timing changes needed for leaner A/F ratios. The whole site has plenty of good reading. HTH |
At this point I'd do a compression test. Also look for burned or unseated valves. You may need to start looking for a replacement engine. Also check your cat converter. If you take it off and dust falls out of it then you cooked it. Those air/fuel ratios are suicidal. It's not going to give you better mileage. You NEED power under load. If you run lean, you end up giving it more throttle so it doesn't do you any good. Not to mention the damage that it does to your engine. Besides abnormal combustion your engine needs fuel to cool down the valves. Run it lean at cruising load but run it safely rich under heavy load and stoich at idle. Look at it this way. When you have the pedal all the way down, is saving gas your priority? No. Getting the car moving is. If you want to save gas, you'll never go into the heavy load portion of the calibration. Idle needs to be stoich in order to be stable. If you run it lean it will hunt and occasionally stall (like when the radiator fan kicks on). It will force you to idle at a higher RPM, so it defeats the purpose. |
Are you using an auxillary fuel? I think at those AFR something else would be beneficial.
actually my egt's are lower from 850f to 700f at cruising
accelerating and dodging traffic doest even reach 600f granted the egt sensor is located 6 inches after the turbine... timing wise... i cant really be sure of the exact # because im using obd1 ecu... but they are really low hey suspended hatch.. saw your sig and im wondering about your set up man since i have an aem ems and im having trouble running it, way toooo different to what im used to |
