VX oxygen sensor pinout?
Where could I find a pinout of the plug on the VX oxygen sensor? I've found plenty of wiring diagrams. But nothing that shows exactly whch pin on the sensor plug goes to what.
sensor wiring
here's wiring
red wire_ high side of differential channel (positive lead for sensor) black wire_ low side of differential channel (negative lead for sensor) clear wire_ Analog ground (for sensor) Green wire_ 12 V port ( positive lead for heater) hope this helps you |
wiring
The wiring I just gave you is for standard sensor, noticed you asked vx sensor wiring
go to following flink, they got it covered very well www.hybridautomotive.com |
