-   -   DFCO on honda civic with chipped ecu (https://www.fuelly.com/forums/f8/dfco-on-honda-civic-with-chipped-ecu-10311.html)
guest001 10-31-2008 06:03 PM
is the DFCO controlled independently of the EEPROM (chip) data? or is it programed into the fuel maps. where the computer accomplishes DFCO by having really lean duty cycles/pulse widths for the injectors in the really high area of the fuel maps where the engine would be when your coasting or let off the throttle really quick at a higher rpm where the vacuum would shoot way up?
how would the ecu even know. My guess is that it would go by vacuum. if not that what else?
I ask and am really curious about this now because at slightly above a half of a tank I started leaving the car in gear instead immediately putting it in neutral on hills and where ever I get a little momentum. and I'm on my way to my best tank ever. finally hitting 40mpg.
GasSavers_Willard 11-04-2008 04:22 AM
using the TPS and VSS as far as I know.
suspendedhatch 11-04-2008 05:27 AM
It's not in the fuel map. It's a separate function.
