1994 Vx On Strike Or Choked On V8 Fumes
Hello all, my 94 vx decided to die on me (ecu stroke due to all the DUB SUV's being back on the road?) and I am pretty sure it is the ecu. (I have a brand new distrib. check engine light stays on even after fuel pump prime clicks off- no trouble codes when jumping connector, CEL just stays lit)
1) are the P07 A00 and the P07 A01 ecu's really interchangeable? (I have a A01 but it seems the A00's are easier to come by) 2)My friend has a CA version with the P07 L02 ECU.. would my car run with that ecu, just to make sure my ecu is bad before buying another one? Thanks in advance for any help!!!!!!!!!!!!!!!!!!!! Jon |
I have a California ECU in Tennessee that I can ship to you if you want to try it out. You just have to pay shipping. Let me know.
To answer the first question, yes the A00 and A01 are essentially identical. I've run them both in my swap and could not tell a difference in any way. As bobski said, they represent different versions of the software in the ECU, but the changes seem to be minimal. If you check the EPA's website, there is a slight difference in mpg between the two years when Honda made the switch (1993 to 1994), but that may also be due to other changes. I'm guessing on your second question, but I think you would probably get a CEL for the O2 sensor with an L02 version. That one used the 4 wire sensor rather than the 5. Otherwise it should be the same though.
Check to make sure the ground near the thermostat housing in the engine bay is attached. That is vital for the ECU.
