Better mileage with premium gas?
Would mileage increase in a car that normally runs on regular? If so, is it even close to being cost effective?
Sorry if this has been asked before... , Bill |
Common question. For most cars, the answer is a resounding "no". Recent information suggests that it could reduce mileage.
Now, while gas is cheap, is a great time to experiment. |
Generally you will get the best gas mileage by running the lowest possible octane without any knock (knock retard)
-BC |
Yeah, no more BTU's in premium unleaded vs regular unleaded.
Bill,
I did some experiments myself about a year or so ago to answer that same question. In summary for my car (3.8 V6 , GM sedan , 4L60E trans. ) taken over about 1 , 500 klms ( around 900 or so miles) and mixed driving with some city , some free way / country the results were: Yes , BUT. In my experience there IS an advantage but the result is not cost effective. The fuel economy is around 5% better on premium but the cost is (or was when I did it ) about 7 to 10% more to buy the stuff. Others may have different results. Cheers , Pete. |
In theory you could get a gain in mileage if:
A. When running on 87 octane your knock sensor in your car is sensing sending signals to your engine computer, and your computer is retarding the timing as a result. B. You build an engine with higher than stock compression, and advance the timing. In either case the added fuel economy does not pay for itself. The money you spend to get that extra MPG is more than you save. -Jay |
Also, I am yet to see higher octane really helps my present cars get noticeably more mpg:D . |
I ran an extended test (for a different purpose) in which I ran Regular, Plus, and Premium. My results were similar to Pete's: I appeared to get slightly better mileage on Premium, but it wasn't cost-effective. Plain old Regular works best for me.
Rick |
I umteenth the 'depends on your car but probably negligable and not cost-effective' vote. under certain conditions my cressida gets better mileage with it and slightly more power.
