A neutral plate could separate the gasses but also looks electrically like a second cell in series increasing the plate surface area and doubling the voltage applied to the outer plates. The Neutral plate one side is positive and the other side becomes negative as the electrons flow from the primary plate set on either side of it. This assumes that the electrical path around the neutral plate is more resistant than going through the neutal plate.
