Although I believe you will see no impreovement from the weight of the wheels/tires, I do believe that diameter and width can have a (small) affect on MPG.
-Bob C. |
I have tires that are .0635 percent larger than the car came with. With it being winter and all, along with more idling, there's no way to tell how much improvement there might be. Come summer I can only return to standard driving practices and compare last year to this year. It would still be difficult. You'd have to be a very consistant driver to get good numbers. That, or you could do the a-b-a thing if the old tires are still around.
Mathmatically, it has to be better. But how much may be difficult to tell. |
Personally, I'm going to go the other way and install the tallest tires that will fit when my whale needs new rubber in a few months. Lowering the gearing is the main goal; the car has plenty of power and revs much more than necessary on the superslab. Stock is 195/60-15. 65 or even 70 (rare) profile tires will fit easily. |
I agree, though; in this case we're talking about marginal amounts. Quote:
Quick update of actual changes:
original wheels and tires weighed in at 32lb each and the VX's weighed 22lb each. pictures here: https://cheaptrixracing.com/delsol FE update coming next week. |
Well, the collection area will lose 0.3 inches, as will the tunnel area between the ground and bottom of the car. Since the tunnel height is a smaller value, the 0.3" represents a greater % change. It seems to follow that the air will indeed be "squeezed" (Ok, not the best verbiage) or forced to travel slightly faster than before. OR, it might 'backup' somewhat, increasing lower leading edge pressure, possibly causing more overall drag. Who knows?? I suspect that undercar airflow is pretty dang turbulent, with chaotic pressure and velocity gradients. How all this will behave with a slight increase in velocity and a slight decrease in chamber height is anyone's guess. Quote:
This from the person who thinks pumping losses are highest when the throttle is closed.... (When there's nothing to pump!) :p -Moo! |
The amount of air it's trying to pump is based on RPM; closing the throttle restricts the air, causing loss. Imagine trying to suck a thick milkshake (or frappe or whatever it's called where you live) through a jumbo straw and a coffee stirrer...which one will require you to use more energy to get an ounce into your mouth? Quote:
if you drastically change the tire size, there will be a difference. I regeared my truck for 4.10s from 3.55s and my mileage went from 22 to 18. a very significant change. I could have done much the same by going from 29 inch tires to 25 or so inch tires.
that was actually suggested to me before changing out the gears. borrow some racing slicks to see if I like the feel of the gearing before changing the gears. it is much easier to change out the tires than change out the gears, especially if a friend would let you borrow them. my take off was excellent and acceleration was much better but I was hitting 2400 rpms at 60 mph vs. 1900 rpms before the gear change. I didn't do the tire trick because I knew I wanted more gear and didn't want to go to 4.56s because that was way too deep a gear for me on stock tires. I know this is an extreme example but diameter will make some difference even if there is a small difference. |
I wonder how many people actually do this. I assume the odometer will always be incorrect and it's just a matter of knowing the correcting conversion when it comes down to logging your miles... (and when you pass by a cop!:p ) |
