-   -   Tire pressure gauges... (https://www.fuelly.com/forums/f8/tire-pressure-gauges-10794.html)
BamZipPow 02-12-2009 03:45 AM
What do you use to make sure yer pressures are even? How accurate is the gauge yer using?
I have always been a fan of the dial gauges...I've owned 2 different Accu-Gages over the years. My current one is a Accu-gage EZ Air that I got fer about $20 shipped. Nice to check the pressure and air up/down without the chuck/gauge/chuck swap that most people do.
Well...I found the perfect system now...the PsiClops gauges/system... I just ordered the Extreme along with the adapter and it should be here by Monday or so. So now I should be able to check all the tires on both vehicles in a few minutes each time instead of the tedious task fer 8 tires which will balloon to 12 tires once the daughter gits her own car. :eek:
Comments? :D
GasSavers_BEEF 02-12-2009 04:06 AM
mine is not that fancy but the gauge only goes up to 60 psi which I like because it is much easier to read than the ones that go to 150 or so.
I do like the features of that one. I paid next to nothing for mine, 5 bucks if I remember right.
*edit* I just looked at your second link. is it really that important to get both the tires at exactly the same pressure? i could understand if you were racing because races are won in tenths if not hundreths of a second.
Mayhim 02-12-2009 04:46 AM
I guess we all have our own peccadillos. Mine is exactness in measuring out beer recipes.
I have a variety of gaues in the cars, in the garage, and down in the shed. They're all approximately within a pound or two. As long as the tires aren't way low and they are the same at each end, I'm happy.
To each their own... It's good to have nice tools, though.
BamZipPow 02-12-2009 04:59 AM
Just looking fer consistencies in tire pressures...and less work per tire when checking/airing them up...especially if yer doing a lot of them. ;)
theholycow 02-12-2009 05:02 AM
The Accu-gage EZ Air reminds me of the inflator attachment I often use:
https://www.chpower.com/chimages/Prod...00AV_large.jpg
You press the lever and it inflates, then when you let go of the lever a telescoping gauge pops out. It's not extremely accurate but I don't care to be extremely accurate.
However, I've frankensteined mine into an easier, more useful condition. That nozzle-ended pipe is a pretty decent way to put air in a tire for a few seconds, and is a necessary evil for inflating the inside tires on a dually, but what's better is having an end that locks on to the valve stem like the Accu-gage EZ Air has on one end. What's even better than that is having a quick-connect fitting and the easy ability to use either fitting, as well as a longer hose.
So, I clip it on to the valve stem and then I can stand up, operating the lever until I'm where I want to be. If I need to inflate a dually (I never do anymore), I can still attach the stiff nozzle instead. Once I'm done I check with a digital gauge.
I agree with BEEF, I don't find it important to be that perfectly accurate from one tire to the next.
GasSavers_RoadWarrior 02-12-2009 05:24 AM
I just use the digital gauge on my tire inflator. Set it to a couple of pounds over what I want it on auto because it drops back a couple when the pump shuts off.
Speaking of such things, anyone know where to get a decent foot pump these days???
bowtieguy 02-12-2009 07:42 AM
HC,
i like that particular air accessary. how much was yours, and does it stay relatively accurate?
asking 'cause my retired air craft mechanic father-in-law claims that the cheap plastic ones lose accuracy and should be replaced regularly.
can't think of a more important tire to maintain than those on a jet/airplane.
theholycow 02-12-2009 07:51 AM
They're inexpensive. I have no reason to doubt its accuracy, though I've never specifically tried to verify it. Mine is from Harbor Freight and probably cost less than $5, but one made by Campbell Hausfeld is still under $20 no matter where you buy it.
There's a variety under $10 at Harbor Freight:
https://search.harborfreight.com/cpis...huck&Submit=Go
Actually, there's one that looks just like the Accu-gage EZ Air for $8.
Northern Tool has a variety of them at vastly differing prices:
https://www.northerntool.com/webapp/w...atchallpartial
Both have this locking nozzle that I forgot about but is quite nice:
https://www.northerntool.com/images/p...159142_med.gif
That nozzle slips on and latches itself to the valve automatically, then you press the release to remove it. It's even nicer than what I use.
Jay2TheRescue 02-12-2009 07:59 AM
I like the digital tire gauges myself. I've been using the same one for years.
bowtieguy 02-12-2009 10:58 AM
HC,
thanks, great links!
