Alternate Radiator Locations
Since the radiator is connected via hoses I was thinking one could in theory locate a cooling heat exchanger in other locations (and with other configurations). I'm not seriously planning this (although I DO have some surplus truck A/C condensors kicking around...), but was curious if it might spark some ideas in any of you folks.
Yes, it is very common when dealing with project truck where the engine is mounted behind the cab in the bed. You wouldn't really gain anything by doing it though for a standard vehicle.
We used to race in an Enduro.
In some of the races we would overheat. So we routed the heater hoses to the trunk, and installed an additional radiator in the trunk (complete with electric fan)- never even came close to overheating again. -BC |
I knew someone with a DeLorean, and it had hoses to hook the radiator up to the rear mounted engine. He had some trouble with it, I seem to recall. That car was a money pit.
I know several ambulance manufacturers place additional A/C condensers underneath the truck, and put electric fans on them to boost the A/C output. I'm sure you could just as easily do the same with a radiator.
They have a shield to prevent rocks and such from damaging them I assume?
NASCAR stock cars have rear axle oil coolers that are just mini radiators for rear oil instead of engine coolant. Those radiators are located under the car with a small electric fan for cooling.
There are really only 2 factors that are impoprtant in the location of the engine coolant radiator: air flow and protection. As long as the radiator is getting enough air flow and is protected from damage, the location isn't important. |
Now that's an idea...what about a servo motor hooked to some sort of shutter than opens when the radiator fans kick on? The electronics are simple for that, so it's really about the shutter design. That has possible retrofit applications. |
A servo motor? That's a wicked-expensive way to do something very simple. A much cheaper thing might be a vacuum-operated solenoid, or even just a DC motor.
Don't forget, though, that warm air generally helps MPG so it is beneficial to pre-heat the air going into the engine compartment... -BC |
