HAI Experiment
I will be conducting an accurate test to either prove or disprove wether a HAI will help on milage.
Parameters: Car: 2003 Saturn LW200 automatic on Khumo ecsta ASX LRR tires (51psi) factory intake with OEM filter. HAI mod for HAI route and a 3" cold air feed for CAI route Test loop: 65 mile loop including stop and go as well as hills and flats. 32 miles out 32 miles back Fuel: Shell premium 92 oct RON+MON/1 test equipment: scangague II and a calculator (for end of run fillup calculation) I will add the road conditions time of day and ambient temperature. |
here are the results first the hot intake
AIT 135f miles traveled 65.2 https://www.fuelly.com/attachments/fo...a5ae0c8524.jpg fuel used 1.53 https://www.fuelly.com/attachments/fo...6f4968d52d.jpg MPG 42.61 Cold intake AIT 71f miles traveled 65.6 https://www.fuelly.com/attachments/fo...ad7ceac851.jpg fuel used 2.018 https://www.fuelly.com/attachments/fo...654dc31a8c.jpg MPG 32.507 tank was filled to 3 clicks (fill till pump clicks off then manual for 2 more) both trips were on the same road Ambient temp was 68f dry road time 12-3pm difference of 10.1mpg Looks like Hot air works better for MPG than cold I hope this puts this issue to rest |
Wow that is an impresive increase.
I have to admit it even surprised me but I'm kind of glad it proved all the labor I put into it was worth it.
its good to see the hard numbers. i knew they helped, but i had no idea it was that much.
Keep in mind your milage may vary but I think I can say without a doubt it works.
Post Removed Due To Inappropriate Language And Personal Attacks.
I presume the outdoor temp was the same as the inlet temp in the second test (71f)? It'd be interesting to see the difference in cold & hot weather as well, although I realize this is work. Maybe once I set it up on my vehicle.
When there's uncertainty, I just use the following: (chance of success)*(estimate of benefit) + (fun of trying) vs (cost & effort to try) + (chance of damage)*(estimated cost of damage) In this case everything on the right hand side is very low. Since the chance of success is mixed, and some people are claiming a good sized benefit I think it's worth giving a shot. |
his test is total BS?
I don't see you doing any testing. it is easy to discredit someone elses efforts. where are yours? he is at least doing something. the whole "not good enough" thing is easy to say when you have done nothing. if you don't agree with his results, do one yourself. disprove him the scientific way, not just by saying it's BS. it is nice to see our newer members contributing so much |
I have to ask myself why does this differ from those $30 vortex air swirling gizmos. I'm sure if I looked I could find somebody claiming success with them.
Well, for a start, no one's trying to sell me anything, so they have no vested interest in lying. Second is that it'll cost a lot less than $30. Finally, there's more doubt (at least to my mind) as to whether or not it may be viable. Take it for what it's worth. |
