just bought my 2nd VX
Hello Everyone,
I just bought my 2nd VX. The first one was a long time ago, and I didn't really care for gas mileage. Now I'm older and wiser ;) This will be my daily driver so I hope to get at least 50mpg if possible. I'm actually thinking of swapping my engine out for a JDM vx engine/transmission. the engine has about 160k miles and the tranny needs a new INPUT SHAFT BEARING. The cost to replace the engine/tranny vs just installing a new input shaft bearing is almost the same.... what do you guys think? |
Repairing your current tranny will not cost you much if you have the tools and time. I replaced the mainshaft bearing on my VX. The only cost was the bearing ($20). I needed to buy a few tools but I have used them after the repair for other jobs. I put in a new clutch at the same time since I was already there.
If you don't want to replace the bearing yourself, installing a JDM engine/tranny might be your best bet since the labor charge to replace that bearing will probably be $500 or more. |
Is the INPUT SHAFT BEARING a thing that is guaranteed to fail in these Civic VX (1992-1995) ?
:confused: :confused: :confused: |
The mainshaft or input shaft bearings tend to fail only if the oil level in the transmission is too low. In my case, one of the axle seals leaked. I found out after I replaced the bearing and saw oil on the subframe behind the axle. Replacing that seal seems to have solved the problem - maybe. I have driven 50K miles on the tranny since the bearing replacement - no noise.
I paid $815 at a local Honda dealer to replace the input and output shaft bearings. I didn't have the know-how to do it myself, and could not find anyone to do it cheaper. Even mom-and-pop shops wanted at least $850 just to look at it.
Ya, I was given a rough estimate of 900 - 1200 to replace the input shaft bearing. Thats why i figured for 800 more I can get a 40k JDM Vtec-E engine and a JDM transmission installed with a new waterpump and timing belt. I'll basically have a pretty new car and hopefully I'll be hitting at least 50mpg. :)
Don't assume that just because the importer tells you the JDM engine has 40k on it that it won't need work. I bought one of those and had to re-ring it. It smoked like an engine with 300k on it. There was very little wear on the bearings, so I don't doubt the mileage, but there was no way I could drive it the way I got it. With only 160k on yours, I definitely would not do a swap unless there is an obvious problem with it.
