Did a quick search, found nothing... VX transmission fluid type?
I recently purchased my Vx (1994), and I was curious to know what type of fluid the transmission takes? I've heard from some shops that it takes motor oil, and I've also heard the extreme opposite, that the transmission ONLY takes Honda Certified transmission fluid...
so which one is it? and what's the actual capacity (3 quarts)? I was going to go with royal purple synochromax, or equivalent. But if someone has a suggestion for a tried and true method (with the least possible amount of fluid resistance but proper lubricating protection) let me know! I was also going to run 0w-20, synthetic in the engine. thoughts/suggestions here? Thanks a lot! |
In my sig meta thread (linked in my sig), there's a link to Honda service manuals. There's no 1993 Civic, but there's 1992 Civic, 1996 Civic, and 1994 Integra.
1992 Civic: https://www.redpepperracing.com/techn...2074-2/aab.png API Service grades SF or SG SAE 10W30 or 10W40 (That's motor oil) 1994 Integra: https://www.redpepperracing.com/techn...9824-3/aab.png API Service grades SF or SG SAE 10W30 or 10W40 (That's motor oil) 1996 Civic: https://www.redpepperracing.com/techn...6051-2/aab.png Honda MTF only (it warns that using motor oil will cause stiff shifting). |
The motor oil in the 94 trans can cause stiff shifting in the extreme cold as well (until the trans warms up). Just go to Honda and get some Manual Trans fluid, it's not really expensive and you only need 2.25 quarts in the trans.
I will personally use Honda MTF or GM Syncromesh. But in the last year, Honda reformulated the MTF to be the same as the GM Syncromesh. |
Thanks again guys! I really appreciate it. the Honda guy said "we only use motor oil as a "temporary measure, until the owner can get the proper transmission fluid into the car".
The issue is the degree of friction the fluid allows. You could use motor oil back in the 80's because it's a simpler formulation than what they use now. Since then, they have added various friction reducing compounds which work great in the engine, but not so great in a transmission. The syncros need some friction in order to operate properly. If they slip too much, it takes longer and/or more force on the shift lever to get them to do their job of speed matching, perceived as stiff shifting.
Honda MTF makes my 270k mile VX trans happy! :) Too bad I have to add a dash each month due to a faulty O-ring for the gear selector. :(
But this trans still shifts smoother than any other Honda trans out of the cars I've owned, I think partly due to using the correct fluid, and partly luck. |
[edit]Horray for censorship -_-*[/edit] |
AFAIK, while motor oil will 'work,' it really isn't the best thing. My Accord's shifting was vastly improved by switching to Honda MTF. Somewhat surprisingly, the stealership price was quite reasonable. I suspect a quality aftermarket MT fluid would do just as well.
