dieselbenz |
08-18-2009 09:20 AM |
Originally Posted by dkjones96
(Post 140032)
The O2 sensor reads O2. If you get a more complete combustion O2 stats fall which the computer reads as rich, just like your chart shows.
You have it totally backwards. Complete combustion (AKA maximum FE) happens near the noX peak and HC minimum where there is still 1-2% unburned O2 left in the exhaust. The O2 sensor will show a LEAN mixture in that situation.
What is your goal? To burn all the O2 going into the engine or all the fuel? You can't do both at the same time. In order to burn the last 1% of O2 inside the engine instead of the catalytic converter, you need to burn an extra 14% fuel over stoich. Great for peak power, not so great for FE. Most people around here want to burn all the fuel because they have to pay money for it, as opposed to the O2 which is free.
