engine feels like it's cutting on and off in 4th and 5th gear
95 civic vx...160k miles...
This happens a lot, but not always. When I drive in 4th and 5th gear, the engine feels like it's cutting off and on. It makes the car jerk a little. It feels as though the engine wants to shut off, but it never does. I know that the O2 sensor is bad, my mechanic told me. Do you think that these symptoms are related to the o2 sensor? What should I do to fix this? thanks -ed |
bad O2 can be a huge contributor to this problem. search on here for where to get the best price on a replacement one.
there is a user here that has a good deal on these oxygen sensors in his signature. he is also a moderator so I am pretty sure it is legit
theholycow if you want to look him up |
There's a link in my sig for the VX O2 sensor at a decent price.
Edit: I haven't bought from them nor am I affiliated, but I think a few users on the forum have bought it. I just put it in my sig because it's so common that people need to find it. |
thanks, but do you guys think the o2 is the problem?
Thank you for the replies, but I want to know if you guys think the problem is being caused by the o2 sensor?
let me know -ed |
That sounds like what mine was doing before I replaced the o2 sensor.
A mechanic said it was the EGR but i never listen so I replaced the o2 sensor. I also bought my new one from the link above and it works great. justin |
Without knowing any more specifics, if you brought the car to me and described those symptoms I would guess that the spark is cutting out, so I'd go for a tuneup (plugs, wires, coils, etc.).
Having said that, it sounds like these other guys have experienced your specific symptoms before, on your specific vehicle, and I have learned to listen to people with that experience. And since you KNOW your O2 sensor is bad, that has to be replaced anyhow so go ahead and see if that fixes things. -Bob C. |
Mine would lose power and slow down for a few seconds, I couldn't hold a steady speed on the interstate. It would do it in lower gears but not as much. As Bob C said if you know the o2 is bad thats a good start.
justin |
Thanks for all your input.
I installed the o2 yesterday, and it's still doing the same thing in 4th and 5th gear. Sometimes in the other gears, but mostly 4th and 5th. I'm going to replace the spark plugs and wires, hopefully this will fix it. I dont know what else to do? please help. |
