theholycow |
06-03-2009 12:14 PM |
Should I buy this thingy?
I still have this JC Whitney gift certificate hanging around from Christmas. I went looking for an oil drain pan and I found this:
https://www.jcwhitney.com/GARAGE-PRO-...7856_10101.jcw
12-VOLT OIL CHANGE PUMP
$12.99- Remove oil without getting under vehicle
- Pumps out oil and sludge through dipstick tube
- For cars, trucks, boats, lawn mowers, tractors and heavy equipment
No need to open engine crankcase drain plug. Lightweight enough for one-hand operation. Instructions included. For all 12-volt systems.
https://www.jcwhitney.com/wcsstore/jc...9601G_CL_1.jpg
The reviews seem pretty good, the worst complaints are about length of the hose and wire, which are easy for me to deal with. Also, I wouldn't be able to use it while the oil is hot; usually I drain it immediately after driving so any suspended junk comes out with the oil (and so the oil flows easily).
Any guesses about whether it will work on the heavy gear oil in my truck's differential? I'd love to suck the oil out instead of taking off the cover, though I should probably open it up to inspect it anyway.
