I still like the idea of removing the plug to be sure all the oil gets drained and any metal shavings that might be in the oil pan drains out with the old oil.
if u dont want stripped threads dont go to walmart! i would avoid that pump OP... |
I do mine the old fashioned way. I just get underneith and do it since I can't even see my oil filter from the top anyway. So for me it would not be convenient since I have to get under there anyway. I also lube and inspect everything under there that I can while I am rolling around there on the creeper anyway.
But for your application it might work since you said you could do everything from the top. So if you decide to get it, let us know how it works. |
No, I couldn't do everything from the top, someone else said that they could. I would still have to crawl under for the filter but it could be significantly less hassle.
No big deal, I'll continue doing it the normal way. |
