imzjustplayin |
08-21-2009 03:48 PM |
Originally Posted by viperguy
(Post 138762)
Well it depends because the VX has 20 more horse than the cx.
Not to mention probably has more low end torque because below the Vtec threshold it can be more optimized for that RPM range while on the CX, it has to have a little bit of high end a little bit of low end. In a sense, the Vtec-E on the VX gives it a huge advantage over the CX. If the VX's VTEC didn't work, running in the 12 valve mode, it'd probably have the same HP as the CRX HF.
