This gets into the big engine small engine problem. I have a friend with a 2.5L v6 in his Sennica and see really poor MPG readings until he gets into a higher gear with his automatic at about 40mph where as in my 1.5L xB I get really high MPG readings lugging it at idle in 5th gear at 20mph like 70mpg on the level road.
This is correct. I have a vacuum/boost gauge in my car and I can see the vacuum per throttle angle. u can get to 0 vac. without opening the throttle all the way. on a map of maf the throttle angle isn't used for fuel enrichment unless the throttle body is open x amount in x amount of time. quick acceleration needs more fuel (in theory). if your moving steady its not even going to do anything. rpm's increasing is going to add more fuel. but like said, at 0 vacuum your at a higher efficiency. I wanted to add you can get to 0 without going into open loop as I've seen it on my vacuum gauge. also how the tps. a vacuum gauge is great for exactly this cause I know exactly how much throttle to use to get to 0. you can also see lugging, the needle shakes. |
Yup, that's what I was talking about too. I don't accelerate any faster than the traffic around me. If you can't control your acceleration enough by shifting because you have too much idle-RPM torque, it won't work for you.
Even if you can, it still may not be the most efficient way to drive your car...it sure is for mine, though. |
Isn't lugging an engine damaging to the rod and main bearings?
Lugging will destroy the engine quickly. Modern engines are equipped with knock sensors and can't lug. They run or they stall. At very low RPM with wide throttle openings they may rumble or growl; the extra vibrations may prematurely wear stuff. I avoid letting that happen.
I would think 75% throttle at such a low rpm would just be hammering the bearings constantly. The engine is attempting to spin faster but cannot due to the resistance of moving the car forward so as the combustion happens it's forcing the pistons/rods down but they cannot move so the force would be put on the rod and main bearings.
That's my thoughts on it but I have nothing to back it up. |
At such a low RPM, there just isn't much power being made. There's so much more torque at higher RPM that the lower RPM can't even begin to stress that stuff.
Basically, the difference between 50% throttle and 100% throttle at, say, 1000RPM, is merely the energy wasted sucking air through the throttle...it's not making much more power, pulling in much more air, or using much more fuel. |
Unfortunately I can't even use that technique....oh well. Thanks for the explanation.
