Mobile site gives wrong date
The last couple of times that I used m.fuelly.com to do a mobile update after midnight my time, the time is correct for my fuel up but not the date. It is always 1 day ahead.
That happened again this morning. I filled up after midnight and instead of being 7/20/12 on the fuel up, it was 7/21/12 until I rolled it back on my computer. I have a droid and I was using the default browser. |
Do you have your time offset set up in your site settings? If not, that could be causing this.
Yup, I have it set. Here is a cut and paste, I have it set at +3
Current server time: 5:57 PM Your preferences time: 8:57 PM |
ok, I'll take a look and see if I can duplicate it. When you scroll down on Fuelly Mobile the date is there. So you might double check and see if it's set right before you post.
I never looked at the date, so I will have to give it a go. I can do a test fill up in a few to see it will happen again.
Just did a test update and the date is wrong again. It was right on the fill up page, but it got saved as the 22nd on my test fill up as the 22nd, not 21st.
Thanks for the extra info. I just found the problem—we were doing an extra timezone conversion after submit that wasn't necessary. So it should choose the correct date on the front end before you submit based on your time offset and now just leave it alone on submit.
Now there is a new problem. When I fill up at 7pm my time, it records 4pm. It has done that for the last two fill ups.
My time offset is still where it should be for the east coast, +3. 4:57pm as I type this. |
Thanks for the heads up. It should be fixed, but let me know if you're still having trouble.
My latest fill up has the correct date and time. Huzzah! Thanks.
