Lint
Why?
When cleaning the lint filter... do my dry fingers slide right over the lint, while a dampened finger lifts the lint right off the screen? |
Some lint from the last time you did it will also take the lint right off.
The same reason there is a meniscus in your glass of water.
-BC |
Coefficient of drag changes due to moisture?
I just use an older piece of lint to grab it. |
i just grab it... everytime it just comes off in one big sheet
I just use my fingernail in one bottom corner to get it started coming off (it is thickest in the bottom corner)- then it all comes off in one big sheet.
still just comes off in a rectangle, few litle clumps but one quick swipe with the hand brushes em off |
If your dryer seems to not get your clothes dry, run it under the faucet - you'll rinse off the invisible dryer sheet residue - and it will pick up lint faster, and dry your clothes faster, too!
Surface tension
