Tire Size vs Economy
Alright guys here it is.
My vehicle stock size tire is 215 70 16 (#1). That size being one choice, I have two others that I'm willing to make. They are 255 60 16 (#2), and 215 85 16 (#3). Stock size tire #1 is 27.9 in diameter and weighs 28 lbs. Tire #2 is 28 in diameter and weighs 32 lbs. Tire #3 is 30.4 in diameter and weighs 38 lbs. All tire sizes noted above will support the vehicle weight, and #1 & #2 have a max psi rating of 51. #3 has a max psi rating of 80. Speed rating on all tires is S. Now here is the question: Which is best for economy and why? Please give an explanation other than so & so says, or so & so has a link in his signature. Thanks, Jim |
Is your driving more stop-and-go or more highway? If the differing weight of the tires will make a large difference, it will be in stop-and-go driving. Also in stop-and-go driving, the gearing advantage of taller tires won't help as much and may even make things worse (since your Astro probably has some decent gears already).
I wouldn't go with either choice #1 or #2 but go with 215/75R16. Slightly taller, and doesn't have the extreme weight penalty.
Not sure if your looking for a truck tire, but the Latitude Tour has the GreenX technology in that particular size which has LRR. Also Michelin has $70 Rebate now. https://www.tirerack.com/tires/tires....omCompare1=yes |
How about my current tire 215 70 16 Nokian WR G2 SUV?
I'm really not familiar with that tire, so couldn't really comment on it. That particular tread design looks to be a better snow tire if you need that capability.
On my Explorer I used to have, I went with the stock size on the door, funny none of the tire stores carried it, so I had to order the size. It was made by General tire and it was cheap, I got 2 for 120 bucks back in 06, the tire store guy said he didn't keep them in stock, because they were so cheap, but since I asked for that particular size, he ordered them for me. The next month I got 2 more, great little disposable tires, my father loves to put huge tires on his SUV's. I went from 16 mpg to 20 average by getting the right size.
Now my father has a new Jeep 3.7 SUV, he averages 12, I drove it for a week and got 24. He drives foot to the floor in the city and goes from 75 to 50 to 75 on the highway. I have watched him drive like this, oscillating for the last 40 years. LOL, he might be behind you right now. |
I'd guess that Bobert's LRR tire suggestion is your best bet, unless some hard data can be found.
Scott, it sounds like your dad is almost pulse & gliding, just get him using neutral as he goes from 75 down to 50 and he should gain some fuel economy... |
