WTB: D15B6 Swap (CRX HF Engine)
I am looking to buy a complete swap, or as complete as I can get, for an 89 CRX HF. Would prefer you to be within 200 miles or so of Indianapolis, IN, but would consider driving farther for the right deal. I am looking for a swap in any (rebuildable) condition, but would prefer one I could just drop right in.
I guess what I should be asking is "what" are you looking for in a "complete" swap package? Are you just looking for the complete engine, or are you also looking for the wiring harness for a multi-port injection HF engine? Are you looking for the ECU as well? Fuel injectors? What about the flywheel? Everything aside from the EFI harness, ECU, & injectors I would figure you need for certain the following: complete engine mechanicals from the intake manifold to the oil pan (exhaust manifold excluded). Just trying to get a feel for exactly what you need.
Sorry for the confusion. In honda world, a swap would include the following:
complete engine and transmission, which means complete, exhaust manifold included mounts shift linkage engine harness ecm axles With these parts, you can put this engine in just about any honda. This is what makes it a "swap". Someone took the swap from this car to install a b16, and I am looking to put it back original for the FE. |
Found one yet?
I thought I'd just drop you a message to see where you've gotten with your HF, D15B6 search. I thought it also wouldn't hurt to mention that, although I don't have a complete "swap" for you, I can offer you some HF parts that I do have. I have a complete bottom-end of the D15B6 (block & all internals; everything except for the cylinder head. I will be able to let the cylinder head go, once I get the time to put my freshly-rebuilt head on. Until then, the other cylinder head is still on my daily-driver. Anyway, I have a lot of stock/OEM HF parts. If you decide you need any HF-specific parts, I'm your guy.
-bri |
