-   -   Proper RPM (https://www.fuelly.com/forums/f33/proper-rpm-12307.html)
theholycow 02-01-2010 08:32 AM
:eek: If I go a long time without driving, I'll probably spend that time sitting.
spotaneagle 02-02-2010 12:05 PM
yea but u dont live in the city where u can walk to get lunch
Geonerd 02-03-2010 09:04 PM
Originally Posted by theholycow (Post 147087)
Geonerd, can you elaborate on what data to collect from the ScanGauge? Just instant MPG, or something more?
I haven't thought it through completely, but something like this has been bouncing around in my head for a while...
Find several long, even hills (poor man's dyno) or various slope (increasing load). Drive up them in different gears/RPM, at different speeds, logging instantaneous fuel consumption and throttle position. I don't even have a SG (no place to plug it in!), but I think they can record T.P., as well as the raw fuel consumption rate, right?
If instant consumption values aren't available, MPG would work as well, so long as you factor out the speed, and wind up with gal/hr, ml/min, etc.
(Is there a SG version that can log several minutes' worth of data? That would kick butt!)
Weigh car. Survey hills. Calculate how much power is required to lift the car up the incline at any given speed. Perform coast-down tests (on level ground!) to determine the power required to overcome rolling resistance and aero at any given speed. Add the two to get (theoretically!) the HP/KW needed/produced to maintain speed up the given hill, at the given speed, and divide into recorded fuel consumption. If all has gone per plan, you now have a number representing power produced per fuel consumption rate. "To make X HP/KW, the engine requires N gallon/grams/liters per minute/hour."
Whatever the units, plotting the resultant values on a grid, located at the appropriate TP and RPM intersection, should make a crude BSFC map.
OK, what did I miss?! (I musta missed something! ;) )
Moo
theholycow 02-04-2010 05:27 AM
You probably did miss something, but it looks good to me. :thumbup:
Geonerd 02-04-2010 07:55 AM
LOL, thanks for the resounding vote of confidence! :D
FrugalFloyd 02-04-2010 10:38 AM
Scangauges don't offer any data logging capability, so that shoots the whole concept of using one to generate BSFC graphs.
NotYourDay 02-04-2010 03:38 PM
Never the less. They still sound like they could give you a whole lot of good gas saving information
theholycow 02-04-2010 03:59 PM
You would have to log the data yourself. The ScanGauge is great at displaying the data, and can average/sum some of the data.
