Thank you. That helped a lot. I still would like to find clarification on few parameters like
Pulses/2 revs = 3ul default but Per wiki jap cars are 1. Confused here!???? Injector DelayuS = 500 ul ...that's default but wifi specific for VX is blank. Does that mean 0 or 500...??? VSS Delay ms = 2 ul .....not sure what VX specific would be ??? Her is what i extracted from my 0.86 code and what you provided if anyone whats to use it. MPGuino Default settings Cut out of officeal MPGuino 0.86 code unsigned long parms[] = { 55ul, 8208ul, 500000000ul, 3ul, 420000000ul, 10300ul, 500ul, 2400ul, 0ul, 2ul, 0ul, 0ul };//default values char * parmLabels[] = { "Contrast", "VSS Pulses/Mile", "MicroSec/Gallon", "Pulses/2 revs", "Timout(microSec)", "Tank Gal * 1000", "Injector DelayuS", "Weight (lbs)", "Scratchpad(odo?)", "VSS Delay ms", "InjTrg 0-Dn 1-Up", "Metric (1=yes)" }; Contrast = 55 ul VSS Pulses/Mile = 8208 ul Civic VX value MicroSec/Gallon(Custom Value to car) = 269113500. Yoshi SuperMID designer value custom to Civic VX. Pulses/2 revs = 3ul default but Per wiki jap cars are 1. Confused here!???? Timout(microSec) = 420000000 ul ...dispaly timeout. Can be anything. Tank Gal * 1000 = 10300 ul ...assign custom value to your car = 10000 = 10 gal tank Injector DelayuS = 500 ul default Weight (lbs) = 2400 ul default ....change to 2094 lbs Scratchpad(odo?) = 0 ul VSS Delay ms = 2 ul InjTrg 0-Dn 1-Up = 0 ul Metric (1=yes) = 0 ul rbhollabaugh gassaver.org member settings #define usedefaults true unsigned long parms[]={45ul,8208ul,269113500ul,3ul,60ul,10300ul,500ul,2 400ul,0ul,2ul};//default values char * parmLabels[]={"Contrast","VSS Pulses/Mile", "MicroSec/Gallon","Pulses/2 revs","Timout Minutes", "Tank Gal * 1000","Injector DelayuS","Weight (lbs)","Scratchpad(odo?)","VSS Delay ms"}; Contrast = 45 ul VSS Pulses/Mile = 8208 ul MicroSec/Gallon = 269113500 ul Pulses/2 revs = 3 ul Timout Minutes = 60 ul Tank Gal * 1000 = 10300 ul Injector DelayuS = 500 ul Weight (lbs) = 2400 ul Scratchpad(odo?) = 0 ul VSS Delay ms = 2ul |
double post. edited and deleted.
Ok did some testing and 3 is DEFINITELY INCORRECT!!!!!! Wiki says 1 is for all jap cars and on 1 my car gives good value where on 3 its weird so i don't trust it. I reset delays to defaults although i'm not convinced that's correct. Guy that sells Jelly bean version drives Geo so Geo values can not be applied to VX. No way |
so why did spotaneagle get banned?
