restricted air intake
HERE IS A VX ENGINE(94)https://www.fuelly.com/attachments/fo...89f277e989.jpg
50mpg(EPA) AND HERE IS A DX ENGINE(94) https://i.ebayimg.com/24/!!fm,q8QBmE~...,4MK0Q~~_4.JPG FROM: https://cgi.ebay.com/ebaymotors/Honda...fCarsQ5fTrucks 41MPG(EPA) THE BOTH HAVE THE SAME STROKE AND BORE SIZE AND BOTH 1.5, BUT AS YOU CAN SEE NOT SO CLEARLY THE AIR INTAKE TUBE ON THE VX IS SMALLER... I'M NOT CLAIMING THIS TO BE A 9MPG IMPROVEMENT, BUT I'VE PUT A SIMILAR SIZE TUBE ON MY SATURN AND HAD REALLY GOOD EFFECTS AS FAR AS MPG ARE CONCERNED Wheelbase 101.3" 101.3" 101.3" 101.3" Overall Length 160.2" 160.2" 160.2" 160.2" Vehicle Height 50.7" 50.7" 50.7" 50.7" Vehicle Width 66.9" 66.9" 66.9" 66.9" Curb Weight 2,390 lbs. 2,178 lbs. 2,094 lbs. 2,108 lbs. Brakes 4 Wheel Disc 2 Wheel Disc 2 Wheel Disc 2 Wheel Disc Engine 1.6L 4 Cyl. 1.5L 4 Cyl. 1.5L 4 Cyl. 1.5L 4 Cyl. Stroke 3.54" 3.33" 3.33" 3.33" Bore 2.95" 2.95" 2.95" 2.95" Horsepower 125 @ 6600 102 @ 5900 92 @ 5500 70 @ 5000 Torque 106 @ 5200 98 @ 5000 97 @ 4500 91 @ 2000 Fuel Capacity 11.9 gal. 11.9 gal. 10.0 gal. 10.0 gal. im begining to think |
the VX has lean burn which jumps the a/f ratio to 17:1 during certain conditions. this is specific to the VX and even more, the california version of the VX doesn't have it and the mileage numbers suffers for it.
I think there are also differences in the shape of the head to better swirl the fuel so that you don't get detonation. there are probably honda guys that can explain it a lot better than me. the VX has a lot of stuff going for it. the original insight also has lean burn which allows it to go to an anstonishing 25:1 a/f ratio (or so I have heard). |
great, but anyone have thoughts on restricted air intakes?
maybe a better comparison in the mileage would be the california version VX vs the DX version. the cali version is the same exact motor but with lean burn disabled (because of emissions) so that would be a better comparison as far as what you are concerned with.
EPA of a cali VX vs. EPA of a DX |
I didn't know the VX went that lean but that is interesting.
I personally am not a honda guy. I know very little about lean burn other than what I have read about on here. I know very little about carbed motors. maybe that shows my age or perhaps my lack of interest in cars early on in my driving years. (side note: really like the SI, wish honda would come back out with a civic hatch) |
I have to agree with the other folks here, the differences are far more than just an intake pipe, and I don't think switching the intake pipe would help. |
1992 HONDA CIVIC HATCHBACKS University of California Energy and Environment Division May 1993 |
"2 The latter estimate is for the "49-State" VX sold in all states but California. The stricter emissions requirements in that state made Honda abandon the lean burn technology for VXs sold there, though the California VX still uses the basic VTEC-E engine and the other efficiency technologies found in the 49 state VX. This compromise reduced the efficiency improvement of the California VX to about 51% relative to the 1991 DX, or to 46.9 mpg composite." COST-EFFECTIVENESS OF FUEL ECONOMY IMPROVEMENTS IN 1992 HONDA CIVIC HATCHBACKS Energy and Environment Division University of California May 1993 |
The VX also had the VTEC-E motor, which heavily increased combustion chamber swirl in low rpm ranges, by only opening one valve of the two. If you notice, the heads are completely different even visually (VX plugs are in the front, DX plugs in the back).
Far more than intake, the head and the lean burn are where the fuel milage gains are. The narrower intake isn't the reason for the FE, it's just a small part of a large package. |
