and I never said i wanted a "miracle" 90MPG Burb, all Im askin for is just a few small tips. other than the obvious: reduce weight, go easy on the throttle, coast to a stop, draft, windows closed, A/C and Defrost off, proper tire PSI. I was hoping yall could enlighten me on a few other lesser known tricks
Weight reduction probably won't help. You'll need to remove 1000 pounds or more from that vehicle before you can begin to measure a FE increase. You can try, though; it can't hurt.
For lesser known tricks, the biggie is Pulse & Glide aka P&G. That's done by accelerating, putting it in neutral until you're going too slow, then accelerating again. It allows you to reduce the quantity of revolutions of the engine over the course of your trip, so less energy is wasted on engine friction and reciprocating loss. It also allows you to operate your engine in a more efficient range where it's producing more work (search for BSFC to understand that a little better). P&G techniques vary. I've found that if I pulse uphill and glide down, it is most efficient AND reduces any issue of holding up traffic because my speed is more steady. Other people have found that using gravity assist for their pulse and then doing the minimum required to climb the hill works better for them. Your truck has the 4L60E transmission which is known for premature failure in heavy applications like trucks. Mine has 192,000 miles on it and is still great, knock on wood. I've been using P&G for almost 20,000 miles without incident. I do rev-match when I go from N->D, which may help. That means I step on the gas so that the engine will be at the correct RPM already when the gear engages, rather than making the transmission force the engine up to the correct RPM. Understand DFCO (Deceleration Fuel Cut Off) and your truck's DFCO behavior. That's when you're off the gas pedal but still in gear, you're engine-braking, and your PCM completely cuts off fuel injection until either you get down to 1000RPM or you step on the gas pedal. Each vehicle has a complicated set of rules for when it will and won't DFCO; my truck has to be engine brkaing for 8 seconds before it will DFCO. It's pretty worthless in mine. Jay's is more cooperative and he tried very hard to use DFCO as much as possible by downshifting, but that may have contributed to his transmission's early failure. OTOH, it's no more work for the transmisison than if it downshifts because you stepped on the gas, so it should be ok but I wouldn't recommend harsh downshifting either way. DWL (Driving With Load) is another strategy. I haven't seen any theory supporting it but some people have had results. DWL is when you choose a position for your gas pedal and you hold it there, letting your speed change with terrain. One modification that might help is an extended air dam. If you can reduce how much air gets under the truck, it may be more aerodynamic. As a side note, you said you do heavy towing; when you do, you should increase your tire pressure for safety regardless of whether or not you want to save gas. |
My truck is more cooperative than HC's when it comes to DFCO. My truck will enter DFCO after 3 seconds of RPM>1,500 & Throttle Position = 0. It will stay in DFCO until you either press the accelerator, or RPM<1,000. |
thank you cow for all the tips. ill try it. the truck has a new transmission as of 10k miles ago. truck is under my moms name and on her policy. I changed my plan a bit, so ill have to wait for my next statement to see what exactly it is now. space in the driveway is a huge issue in me getting a spare smaller car. after the weather gets better, they offered to let me drive the Camry. Unfortunately, I dont know how much longer that thing will last. im definitely getting a second vehicle when I get my own place. might try to air dam.
hey, would a slight wind deflector over the rear hatch help any? maybe divert the wind drag a little?
Here's a tricky one, which works best on roads you travel frequently.
Try to get a feel for the timing cycle of each light. Then if you see one turn yellow/red, hit the brakes as soon as quickly as you can to slow as much as possible, so that you: 1) Get to the light exactly when it turns green, and 2) maintain as many MPH as possible. If you wait too long to brake, you'll have to slow down more, or even stop - but if you hit the brakes early you can hopefully maintain 20-25 MPH when the light turns green. Obviously this is harder to do when you are not familiar with a traffic light. -Bob C. |
how would I fashion a kammback? it would render the liftglass useless. when its opened, the glass is above the roof line. got any ideas?
My thoughts were to fashion one that attached to the frame of the rear glass. Last winter my truck was parked nose into the wind during a blizzard. The resulting accumulation of snow on the back glass was a perfect kammback. I wanted to take photos, but my camera was in the back of the truck. I wished I could have taken many pictures & measurements so I could have replicated it.
