or get black sheets, or carpet, theres alot of black carpet available, its kinda strange, but you could use that cheap black carpet stuff as a solar collector/radiator if you drilled some holes in it and hung it over a window
All you need is to open your sunblind during the day on sunny days. Free and cheap.
And ho! close them if you wanna keep cold air during hot days. |
yes but the black pigment/blue sheet ect adds extra wartmth by far vs the sun hitting white plastic of semi-gloss white paint get a surface tempurature scanner
go sit in a white car then go sit in a black car and tell me which one is warmer |
We used grill/BBQ paint at work on some metal objects that we wanted to absorb heat. It would actually make some of our processes up to 3% more thermally efficient compared to bare aluminum.
(3% might not sound like much, but when you spend $1.5 million on a machine and you can increase productivity by 3% by purchasing a can of spray paint, that's a no brainer...) -BC |
aluminum flashing gets extremely hot in the sun alone, I know from experience, it had a sorts of non reflective surface that is grey, with a dark element to it in a sense
grey on a computer is partly made of of black, same with paint, so you can see where im going with this.. |
Yea, aluminum gets hot, but he's saying it gets hotter with the addition of some black spray paint.
Exactly but I'm inferring that aluminum is a great heat conductor to begin with thats why the aluminum can(painted black) panels work well
https://www.alternative-heating-info....ow_heater.html Then u have this too: https://www.digtheheat.com/Solar/solar_furnace.html I like the top one way better for home use, you can hook it up right out side a window. What I'm doing is basically the same principle Heres the video about it: https://www.youtube.com/watch?v=bRZvA...layer_embedded I have a friend that built one of these. |
I had my window sills painted black and some other stuff at my last uninsulated place. I left it like that too the landlord is a lazy ***. He hasn't done any work to the house since he moved in 30 yrs ago so I was forced to do many improvements. no insulation, 100 year old windows drives you to these things.
Thats how I was getting to 75 degrees on sunny days in the middle of winter, black carpet, black sills, dark cloth, that houses' heating system wasn't capable of heating the house to that temp. I was also using seal and peal. During the month of January you get the best sun for this too, because the rays of the sun come further into your house than in Feb. So during the height of winter I was getting my best results, pretty paradoxical, huh? That house is a tragedy and I should've never moved there in the first place cheap rent is appealing though. |
Stores water as well as adding thermal insulation and helping the air conditioning costs and heating costs as another benefit. Good to see industry getting aware and acting on this. Fly into any major city and the area of roofing over factories and warehouses is vast. Peter. |
I always loved those buildings with vines all over them, I hate when they cut them down... such a shame..
