Brisk Silver spark plugs
I've wanted to try these for a long time, now, but couldn't justify the price. I found out that a friend of mine works at a place that sells them, so I'm going to ask him for a good deal.
If he'll hook me up, I'll try them, and post results. I may do it even at retail price. I would just have to save $30 worth of gas to break even, over the lifetime of the plugs, since they would cost $30 more, retail, than the OEM plugs. For 4 &3 cyl. cars, the investment would be less. I know that they will give me more mileage and HP. I just don't know how much, yet. It may be worth the initial investment, like K&N filters, and synthetic oil. I'll let you know. |
Over the life of the plugs (50-100k miles in a modern car) are you going to be able to discern $30 gas savings that can be attributed solely to the plugs?
actually a good question. i usually stay away from expensive plugs, especially that claim to go 100k miles. even if they can go that long, i don't want them in my block for that long!
https://www.lethalperformance.com/99-...-600hp-p-24986
had to look them up. well, silver is the best conductor. |
100,000 mile plugs in engines designed for a 100,000 mile plug interval are fine.
I'm going to change my GMC's plugs soon for the second time at nearly 200,000 miles. Runs fine now. I'll post pics of them after I get them out, which may not be for a couple months. |
The better choice is a thinner center electrode so that the spark jumps the gap easier due to higher e-field at the finer tip and you can make the gap larger to increase the energy released with the larger spark. Iridium plugs are the way to go as far as I know and they last a long time too. Conductivity is not as important when you have 20-30k volts and only about an amp of current flowing for a fraction of a second.
i'm cheap too, but not that cheap. my luck would be that i would have a problem removing them.
I don't know if it makes a difference, but I'm running a 45,000v coil, and MSD box. I don't know the amps. I'm trying to get the strongest spark possible, for the leanest burn possible. I've seen HP gains on stock cars with these, so I'm assumming that they will help burn lean mixtures (20:1 or more). I also talked to a professional drag racer who swore by them.
