Newb Milelage Charts
Hey People,
So glad I found this forum. My friends and family get sick of hearing me tell them a Honda Civic VX (1993) had a smaller carbon footprint and is more efficient than their Prius. I thought I would post up tanks #3-#8 MPG, measured by dividing miles driven by gallons used. #3: 275 mi. 6.7 gal, 41.2 MPG #4: 323 mi. 8.4 gal, 38.5 #5: 366 mi. 9.7 gal, 38.0 #6: 387 mi. 8.7 gal, 45.0 #7: 328 mi. 8.0 gal, 41.0 #8: 325 mi. 7.7 gal, 42.0 I added things up and got this: 2004 miles, 49 gal. 41.0 MPG average In my notes, now about a year old, I wrote "350 mile max. tank range." I was going from northern to southern cal. and mostly driving flat land. Always stay to the right and keep it 65-70 mph. Just cause I'm old and careful now. The great thing about the VX is that you can drop down to 3rd gear on the freeway and push along pretty good. I got it up to 95 in 4th to get away from a nutcase outside LA one night. People have come up to me and made offers on the car more than once. Trades too. It has 170K miles and I'm the second owner. The old timer (88!) who sold me the car had $6400 in receipts from 2003 to 2009, when I bought it. I had to only install a clutch, now I'm looking at a new CAT and having some trouble finding one for the CA model. I recorded 48mpg on one run around the LA basin off peak hours in no great hurry. 40 is normal commuting long and short here in San Diego. IACV is giving me trouble and throwing a code occasionally, but it resets when the ignition cycles. You fanciers of this model would be jealous of the condition. The inside is flawless and he repainted it after some city dings and scratches. I'll post some pics. Enjoying all your posts. Doug V. |
You're not getting as good of mileage as I think you should be getting. Your car could use a tuneup..
You're doing well, Doug. When you want to kick it up a notch, try 55-60 mph. That should get you high-40 mpg tanks.
This guy should not be getting low 40s high 30s doing 65mph, no way... I get 50mpg in my Civic LX with a 1.6L, stock transmission that has a 4.058 final drive when driving 55mph.. The VX not only has an optimized engine but has a taller final drive in the transmission (3.25) which makes the engine spin slower at highway speeds. Like I said, this car needs a major service/tuneup...
if you really want to talk about carbon footprint of the prius, talk batteries. the batteries use a lot of raw materials and energy to produce and they have to be replaced about every 5 years or so.
for some reason, this little factor isn't incorporated in the prius owners calcuations of carbon footprint |
https://www.npr.org/templates/story/s...38&ft=1&f=1001
https://www.sciencedaily.com/releases...0127134721.htm pavement(flat black) in the sun is 10-15+ degrees warmer than in the shade unfortunately for grass that difference is alot less then think about how this works: https://inventorspot.com/sodacan_solar_furnace it is the same color as pavement Therefor pavement is a culprit I have been doing intensive research on this subject, as I've been a decided environmentalist since the age of 8(unpaid, getting paid ruins your righteousness!), it's really just becoming fun to disprove people left and right because I know so much about it according to the links above air pollution is alot less the cause of global warming, hose links are proof that pavement and rooftops are a big factor possibly even up to 1/4-1/3 or more of the cause of global warming..but regardless, I have done an estimated small math formula to describe the warming rate of black surfaces vs other more relfective/white surface 1 foot of square foot of black pavement= 20 cubic feet of air volume warmed by 1 degree farenheit, based on the square footage I was doing this in(had a solar trap built in).. That is probably way off.. in combination with home heating and cars engines running hot... its not like I'm even trying to brow beat this into you guys, mores |
don't get me wrong I'm not saying we should be spewing pollutants into the air, I'm all for electric engines
there were a lot of dead prius' on craigslist a few years back. all they needed were batteries. maybe it has gotten better with time.
