Anybody done a fuel cutoff switch on '97 Civic (Gen. 6)
I want to put a fuel cutoff switch in my Gen 6 Civic HX. It's a '97.
Has anybody done a fuel cutoff on that generation Civic? Where did you cut in to disable it? I know how to use a good quality relay to open/close the circuit - what I don't know is where to get at the 12V (constant) power to the injectors. The injector grounds are what is rapidly cycled on/off by the computer on this car. |
I put a fuel cut of switch in my HX. Instead of cutting out the injectors I cut out the fuel pump. It works perfect. This also acts as a anti theft mechanism
I put the switch in one of the four inserts on the center counsel |
